Thread Closed
Center of Mass
Share Thread Thread Tools
Dec11-06, 12:52 PM   #1
Center of Mass
[b]1. A composite slab has dimensions of d1=11.0cm, d2=2.80cm, and d3=13.0cm. Half the slab consists of aluminum (density=2.70g/cm^3) and half consists of iron (density=7.85g/cm^3). What are the x coordinate, y coordinate, and z coordinate of the slab's center of mass?
There's a figure in my book where the dimensions are for each the iron and aluminum. In other words, if you find the volume using the dimensions they give you, if you double it you have the volume for the whole figure.
I have no idea where to even begin.
I found the volume for each piece to be 400.4g
I tried finding the mass for each using p=m/v.
For the aluminum I got m=(400.4cm^3)(2.70g/cm^3) = 1081.08g
For the iron I got m=(400.4cm^3)(7.85g/cm^3) = 3143.17g
No clue how to find x, y, and z.....help please!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Dec11-06, 01:01 PM   #2
Recognitions:
Homework Helper Homework Help
If you are saying that each metal is a rectangle 11cm x 13cm with a thickness of 2.8cm stacked to make a total thickness of 5.6cm, then by symmetry the CM position is on a line through the centers of the big ractangular faces. You just need to find the position along the direction of the 5.6cm thickness. You can do that by using the mass and the CM positions of the individual metals.
Thread Closed
Thread Tools
Similar Threads for: Center of Mass
Thread Forum Replies
Center of gravity (it's not center of mass!!!) General Physics 28
the geometric center of the Earth and the center of mass Classical Physics 9
Can two objects with the same center of mass oscillate about that center? Introductory Physics Homework 0
Help with problem of Center of mass, linear mass density and total mass Introductory Physics Homework 1
The center of Mass perfectly match the center of Force-> General Physics 9
