Electricity, Conducting Plates and Magnetic Fields
The discussion revolves around a physics problem involving a pair of parallel conducting plates connected to a voltage source, with an electron moving through the electric field created between the plates. The participants explore concepts related to electric fields, forces acting on charged particles, and the effects of magnetic fields on the motion of the electron.
  • Mixed
  • Participants discuss the calculation of the electric field and the forces acting on the electron, including attempts to determine the conditions for zero net force when a magnetic field is introduced. Questions arise regarding the relationships between the electric and magnetic forces and the parameters involved in the problem.
Some participants have provided calculations and suggestions for approaching the problem, while others have raised concerns about the accuracy of the methods used. There is an ongoing exploration of different interpretations and arrangements of the forces acting on the electron.
Participants note the importance of distinguishing between different variables, such as voltage and velocity, and emphasize the need to calculate forces correctly before combining them. There is also mention of the constraints imposed by the homework context, which may limit the methods available for solving the problem.
Zeus
Howdie all,
I'm soo glad I found this forum, people are genuinely working together instead of ignoring their fellow physics brethren =)
A pair of square parallel conducting plates, having sides of length .05 meter, are .01 meter apart and are connected to a 200 volt power supply. An electron is moving horizontally with a speed of 3 x 10^7 m/s when it enters the region between the plates. Neglect gravitation and the distortion of the electric field around the edges of the plates.
200 V -----> -e 3 x 10^7 m/s
Side length is .05 m
1. Determine the magnitude of the electric field in the region between the plates and indicate its direction on the figure above.
E=-V/d
E=200/.1
E=2000, down
200 V -----> -e 3 x 10^7 m/s!
- vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv (down arrows)
2. Determine the magnitude and direction of the acceleration of the electron in the region between the plates.
E=F/q F=ma
Eq=F
2000 x 1.60 x 10^-19=ma
a=3.513 x 10^14 m/s^2, up
3. Determine the magnitude of the vertical displacement of the elctron for the time interval during which it moves through the region between the plates.
d=vt
.05=3 x 10^7 x t
t=1.67 x 10^-9
d=vt +(1/2)a x t^2
d=.0505 m
4.On the diagram below, sketch the path of the electron as it moves through and after it emerges from the region between the plates. The dash lines in the diagramhave been added for reference only.
.005/////////////////////////////////////////////////////////
(median line)----------------------------------------------
.005
(The line is curving slowly, then faster upward)
5. A magnetic field could be placed in the region between the plates which would cause the electron to continue to travel horizontally in a straight line through the region between the plates. Determine both the magnitude and the direction of this magnetic field.
This is really the one I don't know how to do. I realize that the vertical force must be zero between the magnetic and the electrical force, but I don't know how to do it mathematically.
Thanks, again, for your help =)
1) List all of the forces acting on the electron (there are two). This part is physics.
2) Determine which ones you are allowed "to play with." (There is only one.) This part is engineering.
3) Find all possible arrangements of them that give you what you know you need: zero net force. Choose one (there is still only one). This part is algebra.
4) Realize how these forces are related to certain parameters in the problem (i.e. magnetic field, velocity, plate separation, electric field, ... not all of the ones I mention are relevant). This part is physics.
5) Determine which ones you are allowed "to play with." This part is engineering.
6) Find all possible arrangements of them that give you what you know you need: determined from step 3. Choose one. This part is algebra.
Reply to Turin
Ok, I've given your post some thought:
F=Magnitude of Force of Magnetic field
E=Electric field
theta=@
F=qvBsin(@)
E=-v/d
0=F + E
0=1.60 x 10^-19 x 2000 x B x sin90 - 200/.1
0=(3.2 x 10^-16)B - 2000
B=6.25 x 10^18
Was this the idea?
Thanks Turin
Originally posted by Zeus
Was this the idea?
Roughly. I would recommend using a capital V for voltage and a lower case v (or even something else, like u) for velocity. I think it might have gotten you into trouble and you may want to double check. Also, you cannot add apples and oranges, or, in this case, E-fields and forces. You need to calculate the electric force before you add it to the magnetic force. I will go ahead and work the calculation to see if I get the same answer and then let you know.
My answer does not resemble yours.
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 16 ·
