Thread Closed
Energy to move mass (potential energy)
Share Thread Thread Tools
Dec11-06, 10:20 PM   #1
How much energy is required to move a 900 kg mass from the Earth's surface to an altitude 3 times the Earth's radius?
2. Relevant equations
[tex] \Delta U = GMm[\frac{1}{R_1} - \frac{1}{R_2}][/tex]
[tex] G = 6.67 x 10^{-11} Nm^2/kg^2[/tex]
[tex]R_1 = R_E = 6.37 x 10^6 m[/tex]
[tex]M = 5.98 x 10^{24} kg [/tex]
3. The attempt at a solution
I plugged in everything with [tex] R_1[/tex] = radius of earth
and [tex] R_2 [/tex] = 3(radius of earth) + 1 radius of earth = 4 radius of earth...and got [tex] \Delta U = 4.23 x 10^{10}[/tex].
The answer is [tex] 3.76 x 10^{10}[/tex], where [tex] R_2[/tex] = 3(radius of earth).
Why don't you use the radius of the earth plus the altitude (i.e. 4x radius of earth)? For the first potential energy, I use the radius as the radius of the earth, so I don't see why you use only the altitude for the second potential energy.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Dec11-06, 10:34 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by merced View Post
Your reasoning is entirely correct, [itex] r_f [/itex] {\em should} be [itex] 4 R_E [/itex]. If they used three times the radius of the Earth, they made a mistake, since "altitude" is defined to be measured above ground.
Dec12-06, 12:18 AM   #3
Ok, If I only can tell my professor before the next test!
Thanks!!
Thread Closed
Thread Tools
Similar Threads for: Energy to move mass (potential energy)
Thread Forum Replies
[SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy Introductory Physics Homework 3
Potential Energy of a Two Spring, Two Mass System Advanced Physics Homework 3
Mass-spring potential energy Advanced Physics Homework 8
Mass defect and gravitational potential energy Quantum Physics 0
potential energy mass equivalency General Physics 12
