Help on Contraction: Proving i_v(\omega_1 \wedge \omega_2)
  • Context: Graduate
  • Thread starter Thread starter AiRAVATA
    Contraction
The discussion revolves around proving a mathematical identity involving the contraction of differential forms in the context of a vector space and its dual. Participants are exploring the properties of the contraction operator applied to wedge products of forms, specifically focusing on the implications of a basis and its dual basis.
  • One participant presents a proof involving the contraction of wedge products and seeks clarification on evaluating the tensor product.
  • Another participant suggests a clarification regarding the definition of the contraction operator, proposing it should apply to any k-1 vectors in V, not just the first k-1 basis vectors.
  • A later reply discusses the case when j equals an index in the dual basis, providing a detailed breakdown of the proof steps and the implications of permutations in the evaluation process.
  • Another participant critiques the clarity of the proof presented, suggesting that the justification for certain steps is not clearly articulated and proposes an alternative approach to the proof.
Participants express differing views on the clarity and correctness of the proof steps. There is no consensus on the best approach to the proof, and multiple interpretations of the contraction operator's definition are present.
Some participants note that certain steps in the proofs may lack clear justification, particularly regarding the treatment of permutations and the evaluation of terms that result in zero. The discussion reflects an ongoing refinement of ideas rather than a settled conclusion.
AiRAVATA
Hello guys. Here I am, bothering all of you again...
I am having troubles proving the following:
For [itex]v \in V[/itex] and [itex]\omega \in \Lambda^k(V)[/itex], show that if [itex]v_1,v_2,...,v_n[/itex] is a basis of [itex]V[/itex] with dual basis [itex]\phi_1,\phi_2,...,\phi_n[/itex] then
[tex]i_{v_j}(\phi_{i_1}\wedge ... \wedge \phi_{i_k})=\left\{ \begin{array}{ll} 0 & j\neq \hbox{ any } i_\alpha \\ (-1)^{\alpha-1} \phi_{i_1}\wedge ... \wedge \hat{\phi}_{i_\alpha}\wedge...\wedge \phi_{i_k} & \hbox{if }j=i_\alpha \right.[/tex]
where [itex]i_v \omega (v_1,...,v_{k-1})=\omega(v,v_1,...,v_{k-1})[/itex] and [itex]\hat{\phi}_{i_\alpha}[/itex] means we are omitting that term.
Use this result to show that for [itex]\omega_1 \in \Lambda^k(V)[/itex] and [itex]\omega_2\in \Lambda^l(V)[/itex] we have
[tex]i_{v}(\omega_1 \wedge \omega_2)=(i_v\omega_1)\wedge \omega_2+(-1)^k\omega_1\wedge(i_v\omega_2).[/tex]
Here is what I don't understand. In order to prove the first result, I apply the right side to [itex](v_1,...,v_{j-1},v_{j+1},...,v_k)[/itex], so
[tex]i_{v_j}(\phi_{i_1}\wedge ... \wedge \phi_{i_k})(v_1,...,v_{j-1},v_{j+1},...,v_k)=(-1)^{j-1}(\phi_{i_1}\wedge ... \wedge \phi_{i_k})(v_1,...,v_j,...,v_k)=\sum_{\sigma \in S} (-1)^\sigma \sigma (\phi_{i_1}\otimes ...\otimes\phi_{i_k}) (v_1,...,v_j,...,v_k)[/tex]
I'm stuck at this point. I know I need to evaluate the tensor product, but I'm going nowhere. Please someone enlighten me...
I don't think you mean to define iv on (v1, ..., vk-1) only (since that is just a list of the first k-1 basis vectors of V), but for any k-1 vectors in V, so you probably want to call them w1, ..., wk-1, i.e. you want to define:
[tex]i_v \omega (w_1, \dots ,w_{k-1}) = \omega (v,w_1,\dots ,w_{k-1})[/tex]
To prove the first result, go back to the definitions.
Case 1, [itex]j \neq i_{\alpha }[/itex] for any [itex]\alpha[/itex]. Let's denote vj by w0. We want to prove:
[tex]i_{v_j}(\phi _{i_1} \wedge \dots \wedge \phi _{i_k} ) = 0[/tex]
This is true iff for all (k-1)-tuples of vectors in V, (w1, ..., wk-1), the following equation holds:
[tex]i_{v_j}(\phi _{i_1} \wedge \dots \wedge \phi _{i_k} )(w_1, \dots , w_{k-1}) = 0(w_1, \dots , w_{k-1})[/tex]
The right side is equal to 0, obviously. The left side is:
[tex]i_{v_j}(\phi _{i_1} \wedge \dots \wedge \phi _{i_k} )(w_1, \dots , w_{k-1})[/tex]
[tex]= (\phi _{i_1} \wedge \dots \wedge \phi _{i_k} )(w_0, w_1, \dots , w_{k-1})[/tex]
[tex]= k! Alt(\phi _{i_1} \otimes \dots \otimes \phi _{i_k} )(w_0, w_1, \dots , w_{k-1})[/tex]
[tex]= \frac{k!}{k!} \sum _{\sigma \in S_{\{ 0, 1, \dots , k-1\} }} sgn(\sigma )(\phi _{i_1} \otimes \dots \otimes \phi _{i_k} )(w_{\sigma (0)}, w_{\sigma (1)}, \dots , w_{\sigma (k-1)})[/tex]
Let A denote S{0, 1, ..., k-1}. Then the above equals:
[tex]\sum _{\sigma \in A} sgn (\sigma )\phi_{i_1}(w_{\sigma (0)}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex]
Now for each [itex]\sigma[/itex], there is some n such that [itex]\sigma (n) = 0[/itex]. For this n, we get:
[tex]\phi _{i_{n+1}}(w_{\sigma (n)}) = \phi _{i_{n+1}}(w_0) = \phi _{i_{n+1}}(v_j) = \delta _{i_{n+1}j} = 0[/tex]
with the second last equality holding by definition of the action of an element of a dual basis on an element of the original basis (that [itex]\delta[/itex] being the Kronecker [itex]\delta[/itex]), and the last equality holding because [itex]j \neq i_{\alpha }[/itex] for all [itex]\alpha[/itex], hence in particular, [itex]j \neq i_{n+1}[/itex].
So for each [itex]\sigma[/itex], one of the factors in the expression
[tex]\phi_{i_1}(w_{\sigma (0)}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex]
will be 0, hence each term of the sum will be 0, hence the sum is 0, as desired.
Case 2, [itex]j = i_{\alpha }[/itex]: your turn.
Oh... I see.
In the case [itex]j=i_{n+1}[/itex], for each [itex]\sigma[/itex] there wil be some n such that
[tex]=\sum _{\sigma \in A} sgn (\sigma )\phi_{i_1}(w_{\sigma (0)}) \dots \phi_{i_n}}(w_{\sigma(n-1)}) \cdot 1 \cdot \phi_{i_{n+2}}(w_{\sigma(n+1)})\dots\phi _{i_k}(w_{\sigma (k-1)})[/tex]
and then, taking the change
[tex]i(j)=\left\{\begin{array}{ll} j+1 & \hbox{if } j<n \\ j & \hbox{if } j>n\end{array}\right.[/tex]
the equality becomes
[tex]=\sum _{\sigma \in A'} sgn (i \circ \sigma )\phi_{i_1}(w_{\sigma (1)}) \dots \phi_{i_n}}(w_{\sigma(n)}) \phi_{i_{n+2}}(w_{\sigma(n+1)})\dots\phi _{i_k}(w_{\sigma (k-1)})[/tex]
[tex]=(-1)^{n} \frac{k!}{k!} \sum_{\sigma \in S_{\{1,2,...,k-1\}}} sgn(\sigma)(\phi_{i_1}\otimes\dots\otimes \phi_{i_{n}}\otimes\phi_{i_{n+2}}\otimes \dots \otimes \phi_{i_{k-1}})(w_{\sigma(1)},...,w_{\sigma(k-1)})[/tex]
[tex]=(-1)^{n}(\phi_{i_1}\wedge \dots \wedge \hat{\phi}_{i_{n+1}}\wedge \dots \wedge \phi_{i_{k-1}})[/tex]
What do you think?
I am guessing that in order to apply this result to the next identity I must use linearity.
Your proof ends up being okay, but the way it's written makes it hard to see how you've justified some of the lines. In the second line, it's technically okay to sum over all [itex]\sigma \in A[/itex], but it looks strange, because most of those terms are zero. Also, it kind of makes it look as though for all [itex]\sigma[/itex], [itex]\phi _{i_n+1}(w_{\sigma (n)}) = 1[/itex]. Your permutation i doesn't even have a value at n (although the only remaining choice is i(n) = 0, which ends up being the correct choice). Even though [itex]sgn (i\circ \sigma ) = sgn (\sigma \circ i)[/itex], you really should write [itex]sgn (\sigma \circ i)[/itex] because that's the actual permutation you're applying to the subscripts of the w's. Your second last line goes from summing over A to summing over Sk-1. It's not immediately clear why this is justified. Essentially, it is saying that you can sum over this smaller set because for permtuations [itex]\sigma \in A[/itex] such that [itex]\sigma (0) \neq 0[/itex], the term
[tex](\phi_{i_1}\otimes\dots\otimes \phi_{i_{n}}\otimes\phi_{i_{n+2}}\otimes \dots \otimes \phi_{i_{k-1}})(w_{\sigma(1)},...,w_{\sigma(k-1)})[/tex]
is zero, and Sk-1 consists precisely of those elements in A which fix 0. But why is the above term 0 if [itex]\sigma[/itex] doesn't fix 0? The way you've written the whole proof, I can't clearly explain why this would be the case.
I would do it as follows:
[tex]= \sum _{\sigma \in A} sgn (\sigma )\phi_{i_1}(w_{\sigma (0)}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex] (as computed in post #2)
Define [itex]\tau = (0\, 1\, 2\, \dots \, a-2\, a-1)[/itex]. Then the above is:
[tex]= \sum _{\sigma \in A} sgn (\sigma \circ \tau )\phi_{i_1}(w_{\sigma \circ \tau (0)}) \dots \phi _{i_k}(w_{\sigma \circ \tau (k-1)})[/tex]
[tex]= \sum _{\sigma \in A} sgn (\sigma )sgn(\tau )\phi_{i_1}(w_{\sigma (1)}) \dots \phi _{i_{\alpha }}(w_{\sigma (0)})\phi _{i_{\alpha + 1}}(w_{\sigma (\alpha )}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex]
[tex]= (-1)^{\alpha - 1}\sum _{\sigma \in A} sgn (\sigma )\phi_{i_1}(w_{\sigma (1)}) \dots \phi _{i_{\alpha }}(w_{\sigma (0)})\phi _{i_{\alpha + 1}}(w_{\sigma (\alpha )}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex]
[tex]= (-1)^{\alpha - 1}\sum _{\sigma \in S_{k-1}} sgn (\sigma )\phi_{i_1}(w_{\sigma (1)}) \dots \phi _{i_{\alpha -1}}(w_{\sigma (\alpha - 1)})\phi _{i_{\alpha + 1}}(w_{\sigma (\alpha )}) \dots \phi _{i_k}(w_{\sigma (k-1)})[/tex]
[tex]= (-1)^{\alpha - 1}\sum _{\sigma \in S_{k-1}} sgn (\sigma )\phi_{i_1} \otimes \dots \otimes \hat{\phi _{i_{\alpha }}} \otimes \dots \otimes \phi _{i_k}(w_{\sigma (1)},\, \dots ,\, w_{\sigma (k-1)})[/tex]
[tex]= (-1)^{\alpha - 1}\phi_{i_1} \wedge \dots \wedge \hat{\phi _{i_{\alpha }}} \wedge \dots \wedge \phi _{i_k}(w_1,\, \dots ,\, w_{k-1})[/tex]
so in this case 2,
[tex]i_{v_j}(\phi _{i_1} \wedge \dots \wedge \phi _{i_k} ) = (-1)^{\alpha - 1}\phi_{i_1} \wedge \dots \wedge \hat{\phi _{i_{\alpha }}} \wedge \dots \wedge \phi _{i_k}[/tex]
as desired.
Thanks a lot for your help.
  • · Replies 0 ·
