Diffraction Problem: Calculating Angular Width w/ Steve's Eyelashes
  • Thread starter Thread starter tigerguy
    Diffraction
The discussion revolves around a diffraction problem involving light as it passes through the gaps between Steve's eyelashes. The scenario describes how the angular width of multiple images of green light is perceived when viewed through these gaps, with specific measurements provided for the eyelash diameter and spacing.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the application of diffraction equations, particularly sin(theta) = lambda/W and sin(theta) = 1.22 lambda/D, to determine angular width. There is uncertainty about the correct approach and the definitions of variables such as slit width and order of images.
Participants are actively exploring different interpretations of the problem, with some seeking clarification on the variables involved and others questioning the application of concepts related to single slit diffraction versus multiple slits. Guidance has been offered regarding the nature of the problem as a diffraction grating scenario.
There is mention of confusion regarding the second part of the question, which involves calculating the angular separation between primary and secondary images, indicating a shift in the problem's focus to interference patterns. Participants express uncertainty about the methods to approach this aspect of the problem.
tigerguy
Diffraction and interference occur for wave phenomena such as light and water waves as well as sound waves. During a lecture on diffraction, Steve's eyelids droop,meaning that he closes his eyes until he is looking out through his eyelashes. Then, a green light (lambda= 6 e -7) ini the lecture hall appears to have multiple images, and each image is blurred (wider) than when his eyes are more wide open.
What is the full angular widht (delta theta) of each of the multiple images of the light as viewed through the gap between a pair of neighboring eyelashes? Suppose that the diameter of Steve's eyelashes is 3 x 10^-6 m and the spacing between them is 6 x 10^-6 m.
I think we have to using sin(theta) = lambda/W. For the eyelashes, I think we have to use sin (theta) = 1.22 lambda/D.
So basically, I used that same formula twice, and added the theta's up to get the angle. I don't think that this approach is right, so any advice/guidance would be appreciated.
The wording of the problem sounds to me like you are supposed to be analyzing the pattern of one single slit.
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/sinslit.html#c1
What would the slit width a and the variable m be, then? I don't think we learned that in class yet. Thanks for your help!
The slit width is to be calcualted from the diameter and spacing of the eyelashes. m will be different for each image.
there's a second part of the question that I'm confused about:
Steve also sees multiple images of light due to constructive interference from the light that diffracts through different gaps between his eyelashes. The most prominent secondary images occurs at an angle such that the path lengths of light from the gaps between neighboring eyelashes to the retina differ by one wavelength so that their interference is constructive. What is the angular separation between the primary image (seen with wide-open eyes) and the nearest secondary image (seen through the eyelashes)?
What is the best way to approach this problem? Are we just finding the angles of both, and just subtracting to find the difference? I'm pretty confused, so I'd appreciate any help.
This changes the problem to a diffraction grating problem. The interference is from multiple slits with regular spacing between them. The diffraction from each individual slit is responsible for spreading the light in different directions, but the interference pattern is due to the path length differences from the different slits. The equations are similar, but not quite the same.
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/grating.html
Thanks again;
I found 2 angles for the last problem - would the difference be the angular separation between the primary and secondary images?
Thanks
tigerguy said:
Thanks again;
Thanks
That's the way it sounds to me. The primary image formed when looking through the eyelash "grating" is in the same position as the one image formed with no grating.
11K
