Calculating Satellite Height and Velocity for Geostationary Orbit
  • Thread starter Thread starter Gauss177
    Earth Satellite
The discussion revolves around calculating the height and velocity of a satellite required to maintain a geostationary orbit above the Earth's equator. The problem involves concepts from gravitational physics and orbital mechanics.
  • Participants explore the relationship between the satellite's velocity and the Earth's rotation, questioning how to relate the two variables of velocity and radius. Some express uncertainty about the concept of angular velocity and seek alternative methods to approach the problem.
Participants are actively engaging with the problem, with some providing insights about the necessity of matching the satellite's angular velocity to that of the Earth. There is a recognition of the need to understand angular velocity, even if it hasn't been formally covered in their studies.
Some participants note a lack of familiarity with angular velocity, which may impact their ability to fully engage with the problem. The original poster mentions having two unknowns, which complicates their approach to finding a solution.
Gauss177
Calculate at what height above the Earth's surface a satellite must be placed if it is to remain over the same geographical point on the equator of the earth. What is the velocity of such a satellite?
v = sqrt(G*m / r)
At first I thought the velocity of the satellite would have to be the same as the earth, but since r is different the velocity must also be different. I have 2 unknowns for the satellite, the velocity and r, and can't figure out what to do now.
Thanks for your help.
It must have the same angular velocity as the earth.
Hm..we haven't covered angular velocity yet. Is there another way to do it?
Whether you've explicitly covered angular velocity or not, there's no way around the fact that if the satellite is to "remain over the same geographical point" its angular speed must equal that of the earth. If you think in terms of both the Earth's surface and the satellite sweeping out equal angles in equal times, that might help you figure it out.
  • · Replies 16 ·
  • · Replies 39 ·
