MSN Messenger connection problem
  • Thread starter Thread starter zpidermen
    Connection
The discussion revolves around connection issues with MSN Messenger 7.x, focusing on potential causes and troubleshooting steps. Participants explore various factors that may affect connectivity, including firewall settings, software conflicts, and alternative connection methods.
  • One participant notes that they are unable to connect to MSN Messenger 7.x, despite having previously been able to do so, and seeks assistance.
  • Another participant suggests that the issue may not be with the installation, recommending the use of an error-checking function and considering an upgrade to a newer version.
  • Some participants propose that MSN Messenger 7.x might connect through HTTP if its ports are blocked, indicating that the problem may not necessarily be related to firewall settings.
  • A participant raises the possibility of Windows Messenger running in the background, which could interfere with MSN Messenger's operation.
  • There is a discussion about the potential for Microsoft to provide a web interface for Messenger that operates over port 80, allowing connectivity even when standard ports are unavailable.
  • Another participant emphasizes the importance of checking username and password as a preliminary troubleshooting step.
Participants express differing views on the root cause of the connection issue, with some suggesting firewall-related problems and others proposing alternative connection methods. The discussion remains unresolved regarding the exact cause of the connectivity problem.
Participants have not reached a consensus on the specific troubleshooting steps or the underlying cause of the connection issue. There are multiple assumptions about the functioning of MSN Messenger and the role of firewalls and other software.
zpidermen
Hi, I've MSN Messenger 7.x but I can't connect anymore. I'm behind the Windows Firewall (which I temporarely have disabled) and I'm connecting to the internet with a router, which has a built-in firewall. Can somebody help? Please.
Computer science news on Phys.org
As you have posted that you cannot connect to it anymore, I assume that you could once, so that there is nothing wrong with the installation. Try running the in-build function to find errors. If it is something wrong with your installation you could always upgrade to a higher version. It might also go away by itself (that is, a problem with their network) or you may have malicious programs on your computer. This is all I can do with the little information you have provided.
I think MSN Messenger 7.x can connect through HTTP if its ports aren't open, like many other messengers do, so it might not be a firewall issue.
Do you have Windows Messenger also running, it could be running in the background. This happened to a friend of mine and he had to kill Windows Messenger in order for MSN 7 to start running again.
What do you mean? The destination port on the MSN Server *can* be 80?
I would check your username and password first..
That's right, i think Microsoft exposes a web interface, accessible through port 80, to their Messenger server, so when MSN Messenger's ports aren't available it can use this interface to send/receive messages.
  • · Replies 25 ·
