Harmonic oscillator onboard a relativistic rocket
The discussion revolves around a harmonic oscillator situated on a relativistic rocket, with two reference frames: one at rest on Earth and another moving with a constant relativistic velocity. The participants explore the equations of motion for the oscillator in both frames and the transformations of physical parameters such as the spring constant and damping factor.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the transformation of equations of motion between the two frames and question the validity of applying relativistic transformations to non-relativistic quantities. There are inquiries about how the oscillation frequency transforms and the implications of damping on the system's behavior in different frames.
The discussion is ongoing, with participants providing insights into the nature of the transformations required for the oscillator's parameters. Some suggest that the solutions of the equations must also transform correctly, while others express uncertainty about specific transformations and their implications.
Participants note the challenge of transforming quantities like the damping factor and spring constant, particularly in the context of relativistic effects. There is also mention of the need to reconcile non-relativistic behavior of the oscillator with relativistic transformations.
Methavix
We have a first frame S (named coordinate frame) at rest on the Earth (we suppose a non-rotating earht and this frame as a perfect inertial frame) and a second frame S' (named proper frame) moving in respect to the first with a constant relativistic velocity V along the x-axis.
The second frame is fixed to a relativistic rocket where onboard is placed a non-relativistic oscillator: mass-spring-damper system. The oscillator swings classically (that is at non relativistic velocities) and I want to write its equations of motion (and their solutions) in the proper frame and in the coordinate frame, also to find the tranformation of the spring constant and the damping factor from a frame to the other.
I know the equation of motion in the proper frame:
m'*d2x'/dt'2+b'*dx'/dt'+k'*x'=0
where x' and t' are the coordinates in the S' frame, b' is the damping factor and k' is the spring constant in the same frame.
Besides I define:
gamma = 1/sqrt[1-(V/c)^2]
d2x'/dt'2 = a'
dx'/dt' = u'
I can directly transform all quantities from this equation :
(m/gamma)*(a*gamma^3)+(b')*[(u-V)/(1-u*V/c^2)]+(k')*(x*gamma) = 0
but i cannot transform b' and k'.
Besides, being u' not relativistic can I do anyway this calculation?
thanks
Some other ways to get a handle on the other transformations:
1. If the oscillator is underdamped, it is effectively a clock so its oscillation frequency must transform correctly.
2. The 3 terms mx" bx' and kx have the same units (force) so if you can transform one of them the transformation for the other two must be the same.
3. Some features of the motion would be observed the same in both frames - e.g. both observers would see the same number of oscillations for the amplitude of an underdamped oscillator to reduce by half.
what does it mean? i mean, how can i transform the oscillation frequency? is there a known law for it?
but i can't do it since gamma has not unit of measurement.
if i write this known transformation:
m'*a' = m*a* gamma^2 --> means that i have to transform this quantity as follows b'*u' = b*u*gamma^2 ?
besides, I found m'*a' = m*a* gamma^2 but F=F' if they are in the x direction, right? is it in disagree with my result?
sorry, but what do you mean?
thanks
luca
The general point I'm making is that the solutions of the equation (i.e. what you could observe about the system from the other reference frame) also have to transform correctly.
If b = 0, there is a solution x = A sin wt where w^2 = k/m. That could be used as a clock sending a "tick" at intervals 2 pi/w. If you observe the clock from the other system you know how time is tranformed.
For a lightly damped system a solution is of the form Ae^{-pt}cos wt. (This is not the same w as in the undamped solution of course). The decay in amplitude in one cycle is e^{-2 pi p/w}. That amount of decay must be the same when observed from the other system so p/w must be the same in both systems.
get a four vector solution to the oscillator in the rocket's frame (x,t) and smack a Lorentz transformation matrix in front of it?
ok, if we suppose to have an undamped system the solution in the rocket's frame is (as you write):
x'(t') = x'(0)*cos[sqrt(k'/m')*t']
but the transformation i have to do is:
x'(t') = (x(t)-V*t)*gamma
m' = m*gamma*[1-(u(t)*V)/c^2]
t' = gamma*[t-(x(t)*V)/c^2]
right? because the mass is moving in respect to the rocket frame with a velocity u'(t'), but on the other hand u' is non-relativistic... so I'm not sure...
if these transformations are correct, we yield:
(x(t)-V*t)*gamma = x(0)*gamma*cos[sqrt(k'/(m*gamma*(1-(u(t)*V)/c^2)))*gamma*(t-(x(t)*V)/c^2)]
if i did right, what can i do to continue?
thanks
  • · Replies 17 ·
