Determine the change in internal energy of boiling water
The change in internal energy of 1 kg of water at 100 degrees Celsius when fully boiled into steam at 1 atm is calculated to be 2,090,728 J. This is derived from the heat added, Q, which is 2,260,000 J, and the work done, W, which is -169,272 J. The calculation for the number of moles of water converted to steam yields conflicting results: 54.6 moles using the ideal gas law and 18 g/mol based on molar mass, indicating a misunderstanding of the terms. The correct approach requires clarity on the definitions of moles and mass.
  • Understanding of thermodynamic principles, specifically internal energy changes.
  • Familiarity with the ideal gas law and its application in calculating moles.
  • Knowledge of phase changes and the associated heat transfer calculations.
  • Basic chemistry concepts, including molar mass and its significance.
  • Study the first law of thermodynamics and its application to internal energy calculations.
  • Learn about the ideal gas law and its implications for calculating moles of gas.
  • Explore phase change thermodynamics, focusing on latent heat and its calculations.
  • Review molar mass calculations and their relevance in chemical equations.
Students in thermodynamics or physical chemistry, educators teaching these concepts, and anyone involved in energy calculations related to phase changes of substances.
cowgiljl
Determine the change in internal energy of 1 kg of water at 100 degrees C when it is fully boiled. Once boiled this volume of water changes to 1671 Liters of steam at 100 degrees C Assume the pressure remains constantat 1 atm
things i know
1 L =1E-3 m3
1atm = 1.013E5 N/m2
1 L = 1000 cm3 = 1E-3 m3
formulsa used
Q=mLv = 1kg*2.26E6 J/k Q=2260000 J
W = -P(Vsteam-Vwater) = (1.013E5)*[(1.670 m^3) = - 169272 J
change in U = Q+W
2260000-169272
U = 2090728 J
are these correct?
Now i have not took chenistry yet but it wants to know how many moles of water were converted to steam
I have 2 different answers
1) 54.6 mols using n = PV / RT= 1.013E5*1670 / 8.31*373.15
or
2)18g/mol using the back of the book periodic table (molar mass)
H2O = 1+1(of hydrogen)+16 (oxygen)
which is right if somebody can help me befor 300pm today Please
thanks joe
things i know
1 L =1E-3 m3
1atm = 1.013E5 N/m2
formulsa used
change in U = Q+W
2260000-169272
U = 2090728 J
are these correct?
I haven't checked the numbers, but the procedure is right.
or
which is right
The "54.6 mols" and "18g/mol" aren't compatible quantities. The first tells you how many moles you have and the second tells you the mass of a mole.
thanks joe
Sorry I was late.
Thanks a lot for the reply, at least i am starting to get a grasp on this subject. And doing better in the class
Thanks again Tom
joe
14K
