Integrating with Velocity: A Question of Correctness
  • Context: Graduate
  • Thread starter Thread starter Fallen Seraph
The discussion focuses on the integration procedure for deriving velocity from the equation a = -kx. The user initially attempts to manipulate the equation by multiplying both sides by v and integrating, leading to confusion regarding the treatment of v as a constant. A key correction is provided, suggesting the rewriting of the term d²x/dt² * dx/dt as (1/2) d/dt((dx/dt)²) before integration, which clarifies the derivation process and leads to the correct expression for velocity.
  • Understanding of classical mechanics concepts, specifically Newton's second law.
  • Familiarity with calculus, particularly integration techniques.
  • Knowledge of differential equations and their applications in physics.
  • Proficiency in manipulating mathematical expressions involving derivatives and integrals.
  • Study the derivation of energy conservation principles in classical mechanics.
  • Learn advanced integration techniques, including integration by parts and substitution.
  • Explore the application of differential equations in modeling physical systems.
  • Investigate the relationship between force, mass, and acceleration in various contexts.
Students of physics, educators teaching classical mechanics, and anyone interested in mastering the mathematical foundations of motion and forces.
Fallen Seraph
Sorry for the undescriptive title, but I couldn't think of a better one.
My question is essentially this: is the following procedure correct?
a=-kx and we want v.
Multiply both sides by v to get:
[tex]\frac {d^2x} {dt^2} * \frac {dx} {dt} = -kx *\frac {dx} {dt}[/tex]
Now, by dt, and some rearranging :
[tex](\frac {d^2x} {dt^2} dt) * \frac {dx} {dt} = -kx *dx[/tex]
And the step which I'm not convinced can be done:
[tex]( \int \frac {d^2x} {dt^2} dt) * \frac {dx} {dt} = -k \int x *dx[/tex]
and so we end up with v^2 = -(kx^2)/2 +c which is but an errant 1/2 away from what I need.
I just don't trust integrating a wrt t, while having a v just sitting there as if it were a constant. The only reason that I haven't already disregarded it is that it checks out if you analyse the dimensions...
No, that's not right. As you mention, you're treating v as a constant, and it isn't.
You started out right, you just need to rewrite:
[tex]\frac {d^2x} {dt^2} * \frac {dx} {dt}[/tex]
as:
[tex]\frac{1}{2} \frac{d}{dt} \left( \left(\frac{dx}{dt} \right)^2 \right)[/tex],
then integrate.
Wow, quite the nifty identity. Thanks a lot for that help.
  • · Replies 19 ·
