Radius of convergence of power series
The radius of convergence for the power series \(\sum\limits_{k = 1}^\infty {2^k z^{k!} }\) is determined to be \(R = 1\) using the Cauchy-Hadamard criterion. The criterion states that \(R = \frac{1}{L}\), where \(L = \lim \sup \left\{ {\left| {a_k } \right|^{\frac{1}{k}} } \right\}\). In this case, the sequence \(a_n\) is defined such that \(a_n = 2^k\) when \(n = k!\) and zero otherwise, leading to a straightforward calculation of the limit superior.
  • Understanding of power series and convergence
  • Familiarity with the Cauchy-Hadamard criterion
  • Knowledge of limits and limit superior
  • Basic combinatorial concepts related to factorials
  • Study the Cauchy-Hadamard theorem in detail
  • Explore examples of power series with non-standard exponents
  • Learn about the implications of radius of convergence on series behavior
  • Investigate the relationship between factorial growth and convergence rates
Mathematics students, particularly those studying complex analysis or series convergence, as well as educators looking for examples of applying the Cauchy-Hadamard criterion in practice.
Benny
Find the radius of convergence of the following series.
[tex] \sum\limits_{k = 1}^\infty {2^k z^{k!} } [/tex]
The answer is given as R = 1 and the suggested method is to use the Cauchy-Hadamard criterion; [tex]R = \frac{1}{L},L = \lim \sup \left\{ {\left| {a_k } \right|^{\frac{1}{k}} } \right\}[/tex]
I don't know where to begin. The sequence a_k in the Cauchy-Hadamard criterion is for series of the form [tex]\sum\limits_k^{} {a_k z^k }[/tex] but the series here has z raised to the power of k!, not just k. Substituting something for z (ie. set w = z^2 if the summation was over z^(2k)) doesn't work here. Can someone help me out? Thanks.
k! is a subsequence of n.
If it helps that series can be restated as
[tex]\sum_{n=1}^{\infty} a_nz^n[/tex]
where a_n is given by:
if n=k!, then a_n=2^k
zero otherwise.Clearly, terms that are zero have no effect on the limsup, so all you need to work out is
[tex]\lim\sup (a_n)^{1/n}[/tex]
well, a_n is either zero, or if n=k!, then (a_n)^1/n = (2^k)^{1/k!}, so the lim sup is easy to work out (and is 1).
Thanks matt, I didn't think of looking at the series like that. Perhaps I could have started by considering the sequence of partial sums and the answer might have dropped out. Anyway, thanks again.
