Sunspots: Viewing at Home - Simplest Method
  • Context: High School
  • Thread starter Thread starter wimms
    Home Sun
The discussion revolves around methods for viewing sunspots at home, focusing on the simplest techniques and safety considerations. Participants explore various approaches, including projection methods and the use of telescopes, while addressing potential risks to equipment and eyesight.
  • One participant suggests using a small hole in cardboard for solar viewing, noting that while it can project an image, the size is limited to about 6 inches in diameter.
  • Another participant mentions using a telescope with eyepiece projection for greater detail, but emphasizes the importance of not looking directly through the telescope at the sun.
  • A participant shares their experience using a survey transit to project images of the sun, reporting no damage to the equipment over years of use.
  • Concerns are raised about the risk of damaging telescope optics when viewing the sun, with one participant recounting instances of eyepieces being destroyed due to solar observation.
  • Another participant advises caution and thorough preparation when using telescopes for solar viewing, highlighting the dangers of concentrated solar energy.
  • One participant recommends simple projection methods without using an eyepiece to avoid potential damage to the telescope.
Participants express varying opinions on the best methods for viewing sunspots and the associated risks. There is no consensus on the safest or most effective approach, and concerns about equipment damage and eye safety remain prominent.
Participants discuss limitations related to the size of projected images and the potential for damage to optical components. The conversation reflects a range of experiences and recommendations without resolving the uncertainties involved.
Amateur astronomers, hobbyists interested in solar observation, and individuals seeking safe methods for viewing sunspots may find this discussion relevant.
wimms
Is it possible, and what would be simplest means to view sunspots at home? I figured some projection on the wall would be nice, but what you'd need to a get sharp image of say 2ft diameter?
Astronomy news on Phys.org
Hi Wimm,
A very simple solar viewer is simply a small hole poked in a piece of cardboard. If you move the cardboard away from the surface it is projecting onto, you will see a focused image of the surface of the sun. Stray light makes it difficult to see much detail though so a box with a pin hole and a viewing hole might do the trick (you'll still not approach anything close to 2 feet in diameter, however ~6"). Probably the next best way would be to use a small refractor or reflector telescope and use eyepiece projection (CAUTION: NEVER LOOK DIRECTLY THROUGH THE TELESCOPE AT THE SUN), because the sun's light is gathered by the optics and can be projected a greater distance and subsequent magnification reveals greater detail. Still 2 feet is probably pressing it as far as useful detail is concerned, I'd stay with about 6-10" even with a small scope.
bb
any risk to the optics of the telescope?
I use to do that with a survey transit/theodilite
mostly during eclipes but some times just to look at sun spots to project a 5 to 8 inch image of the solar disk on paper
never noticed any bad effects and the insterments were used daily for years in a controlled checked condisions of land surveying
Being a beginner amateur astonomer I have read a lot of stuff on the net about this and no one has posted anything regarding damage. You can also by sun filters which will reveal more detail on your projection from a telescope. Before you attempt anything with a scope and the sun, I would do some serious reading and preparation. As has been said before you are dealing with quite a bit of concentrated energy by viewing the sun in this way and anywhere near your eye means goodbye sight!
Many good eyepieces have one or more cemented elements (usually two at a time) and I have seen four destroyed in just one day of showing the public some sunspots (not MY scope). In cheaper scopes, the eyepiece housings just simply melt.
Labguy,
Good point. I should have recommended simple projection without the eyepiece. If you have a goto telescope you can center and follow the sun projected onto a white card and damage can be avoided.
bb
  • · Replies 226 ·
18K
  • · Replies 460 ·
65K
  • · Replies 34 ·
  • · Replies 49 ·
