| Thread Closed |
Clean the POM |
Share Thread | Thread Tools |
| Jan18-07, 12:14 PM | #1 |
Clean the POM
For my Production and Layout II class I need to come up with a a fictional product I'm trying to sell in the ad. Getting to the point, I want to use a POM tea glass as my container, but try as I might, I can't get the lable off the glass. Even with my Dremel set to full power. I don't want to use the carbide bits, I know they'll get it off, but they'll damage the glass. I have no clue what the lable is made of, never seen anything else like it. Tough, tough stuff, whatever it is. Any idea of how I can get it off without damaging the glass?
Wasn't sure which sub-forum to put this one under, if it's the wrong place, please feel free to move it. |
| Jan18-07, 05:36 PM | #2 |
Is the "glass" actually made of glass? Have you tried a sand/bead blaster? Have to tried a dip in methanol and acetone?
| Jan18-07, 07:46 PM | #3 |
Is the label glued on or painted on? To remove most glued-on labels, I get off as much as possible with an initial soak in hot water and scraping with a razor blade, then alcohol. Gokul suggested methanol, but ethanol also works on most labels...I've never tried isopropanol (rubbing alcohol), but that is usually more readily available to the average student. A good steel wool scrubbing usually takes the rest off (as long as it's glass...plastic will get scratched by steel wool). As Gokul suggested, acetone may also work if the label is painted on or has a plastic coating resistant to other solvents. In case you didn't know, a good source of that is regular nail polish remover. That will destroy a lot of plastics, so be careful where and how you use it.
If none of that works, or has already been tried, let us know what else you've already tried and as much as you can about the label itself (it's hard to tell from the photo). |
| Jan18-07, 08:12 PM | #4 |
Clean the POM
If you have access to it, also try some dichloromethane. It is used in paint thinners so it might help take it off.
| Jan30-07, 07:52 PM | #5 |
I would really appreciate if you could let me know whether you've found a way to remove the POM label. I love the drink and have lots of the bottles hanging around and would hate to waste them! Thanks so much!
| Feb5-07, 12:30 AM | #6 |
Thanks for the suggestions, guys. I've picked up a few of the suggested solvents. Yet to try them out though. I'll report the results.
| Feb5-07, 04:14 PM | #7 |
The label is probably an epoxy printing ink. Good luck getting it off without marking the glass.
If it were me, I would use aqua regia and a good hood or a strong peroxide and base like NaOH and 30% H2O2 (piranah etch). |
| Mar16-07, 10:39 PM | #8 |
I did some internet research and found this comment on another forum:
The only relative success I've had is from using a nail file (I assume some fine grained sand paper will also work) to rub the label off. The remaining area is kind of "blurred" or "smokey." |
| May30-07, 01:15 PM | #9 |
I found your post while i was researching the same exact thing myself (removing the pom label)
Apparently the people brewing their own beer had a solution that got rid of the ACL labels but i dont know how well it works (havent tried it myself yet was waiting on getting some feedback from them) But apparently a cleaning solution called Star San works. If you let it sit a couple days in that it will eat off the label. Though it either has to dry for it to come off, or just fall off like rust depending on comments of people. I figured I'd mention it if you still needed the info |
| Jun13-07, 08:23 PM | #10 |
Test completed. 2 days (about 46 hours) 1 oz of Star san, 2.3 gallons of water.
result: upon rubbing down the Pom Tea bottle with a few paper towels, No label remained, nothing on it at all. |
| Aug3-07, 04:25 PM | #11 |
Interesting, thanks.
I ended up just sandblasting the label off. That frosted the glass quite nicely, but that ended up being what I actually wanted for the fictional beverage product.
| May29-08, 11:57 PM | #12 |
What is star San? I want to make a hookah out of one of the large POM bottles, and having no labels would be awesome.
Also, How does one get random items sandblasted? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Clean the POM
| Clean and fix up | General Discussion | 41 | ||
| Evo, clean out your PM box!!! | General Discussion | 12 | ||
| Who's helping with the Tsunami clean up | Current Events | 0 | ||
| Let's try to keep it clean | General Discussion | 51 | ||
