How Do You Calculate the Amount of Product from Limited Reactants?
  • Thread starter Thread starter bluegirlbalance
This discussion focuses on calculating the amount of product formed from limited reactants in chemical reactions, specifically using the example of creating fake blood from white grape juice and food coloring. The calculations demonstrate that the limiting reactant determines the maximum number of batches that can be produced, with the final answer being 7.5 batches based on the available ingredients. Additionally, the discussion includes a detailed explanation of how to calculate the grams of sulfur dioxide (SO2) produced from given amounts of sulfur (S) and oxygen (O2) using balanced chemical equations and mole conversions.
  • Understanding of stoichiometry in chemistry
  • Knowledge of balanced chemical equations
  • Ability to convert grams to moles
  • Familiarity with limiting reactants in chemical reactions
  • Study the concept of limiting reactants in greater detail
  • Learn how to balance chemical equations effectively
  • Practice converting between grams and moles using different substances
  • Explore real-world applications of stoichiometry in chemical manufacturing
Chemistry students, educators, and anyone interested in mastering stoichiometry and chemical reaction calculations.
bluegirlbalance
I totally need help on these problems about limited reactants. My teacher gave me an example: You intend to use the following recipe (Caution: it will turn your mouth bright red—be careful):
1 can frozen white grape juice concentrate
2 Tbs. red food color
1 tsp. yellow food color
Suppose for your movie you need to make 10 batches of this fake blood. In your freezer you have 9 cans of white grape juice, you have 15 tablespoons of red food color and you have 8 teaspoons of yellow food color. Obviously, you need to go to the store, but how many batches can you make?
9 cans of white grape juice will make 9 batches.
15 tbs. of red food color can make 7.5 batches (2 tbs. each)
8 tsp. of yellow food color can make 8 batches.
So...The answer must be 7.5 batches if you want to make half a batch.
Then she gave me these equations to solve:
1. How many grams SO2 can be formed from 20.0 g of S and 160g O2?
2. How many gramsSO2 can be formed from 20 g S and 15.0 g of O2?
(Plese show the balanced equation and your work.)
The balanced equation is S + O2 ---> SO2. What I don't know how to do is the work to figure out the equations above.
This is why measurement in moles is so useful. You can come up with certain equivalencies from your balanced equation:
1 mol S can yield 1 mol SO2
1 mol O2 can yield 1 mol SO2
Then convert your given amounts of S and O2 from grams to moles. You can then use those equivalencies. I won't solve your problem but I'll show you how to do a similar problem:
2H2 + O2 --> 2H2O
The atomic weight of H is 1 g/mol, so the molecular weight of H2 is 2 g/mol. The atomic weight of O is 16 g/mol, so the molecular weight of O2, is 32 g/mol.
Now our equivalencies (which we get from the balanced equation above):
2 mol H2 = 2 mol H2O
1 mol O2 = 2 mol H2O
Say we are given 14 g H2 and 50 g O2. Convert these amounts to moles:
[tex] \frac{14\,g\,H_2}{1} \frac{1\,mol\,H_2}{2\,g\,H_2} = 7\,mol\,H_2[/tex]
[tex] \frac{50\,g\,O_2}{1} \frac{1\,mol\,O_2}{32\,g\,O_2} = 1.5625\,mol\,O_2[/tex]
Now use the equivalencies we have from the reaction equation to see how much of the product will be made given our reactants:
[tex] \frac{7\,mol\,H_2}{1} \frac{2\,mol\,H_2 O}{2\,mol\,H_2} = 7\,mol\,H_2 O[/tex]
[tex] \frac{1.5625\,mol\,O_2}{1} \frac{2\,mol\,H_2 O}{1\,mol\,O_2} = 3.125\,mol\,H_2 O[/tex]
As you can see, given our amount of H2 and O2, we can only make 3.125 mol H2O. O2 limits the reaction since it it all used up when this much H2O has been made, production of H2O stops, and we have some extra H2 left over.
  • · Replies 21 ·
21K
10K
  • · Replies 21 ·
9K
12K
