How to calculate the exact wavefunction of two electrons in a 1-d infinite well?
The discussion revolves around calculating the exact wavefunction of two electrons in a one-dimensional infinite potential well, considering their interaction through Coulomb forces. Participants explore theoretical approaches, mathematical transformations, and the implications of fermionic behavior.
  • Some participants question whether the problem is solvable exactly, given the complexities introduced by electron interactions and boundary conditions.
  • One participant suggests using a coordinate transformation to simplify the problem, proposing new variables to represent the positions of the electrons.
  • Concerns are raised about boundary conditions affecting the ability to separate variables in the transformed coordinates.
  • Another participant emphasizes the difficulty of the problem if the electrons are interacting, noting that the wavefunction of non-interacting particles can be expressed as a product of individual wavefunctions.
  • Some participants discuss the potential to ignore spin initially and focus on spatial aspects, while others argue that both must be considered simultaneously due to the nature of fermions.
  • One participant proposes using approximation techniques and numerical methods due to the challenges of analytically solving the problem.
  • Another participant outlines a method involving the product of Hilbert spaces and suggests a way to incorporate the Coulomb interaction into the Hamiltonian, while also noting the complexity of diagonalizing the resulting matrix.
  • There is mention of a different transformation approach that could allow for separating the potential, although it introduces complications with non-orthogonal coordinates.
Participants express a range of views on the solvability of the problem, with no consensus reached. There are multiple competing approaches and ongoing debates about the implications of boundary conditions and the treatment of fermionic properties.
Limitations include unresolved mathematical steps regarding the separation of variables and the treatment of boundary conditions in transformed coordinates. The discussion also reflects varying levels of familiarity with advanced mathematical frameworks.
peter308
as title,
the electron's interaction is coulomb force.
1.is it unsolvable?(exact solution)
2.will computer simulation be the only way to work it out?
thanks a lot,dude
Try a coordinate transformation. This is a 2-D problem particle-in-a-box problem with a twist: another potential. I am trying the coordinate transformation:
η = x - y, ξ = x + y.
EDIT:
Sorry, I typed that without much explanation. I will now reveal the secret meaning of those variables. I intended x to be the position of one of the electrons and y to be the position of the other. This would give a 2-D box problem with a ridge of infinite potential running along one of the diagonals that tapers off at the opposing corners.
the way u solve the problem will encounter some difficulties,one is the bondary conditions(infinite well!),as u transfrom the coordiates,
the boundary will transfrom,either .and i believe this will result in the conditon that u can't separate your variables!by the way,i am grateful y give me replies!
How is the problem stated orginally, is it "two non-interacting particles" in a 1-d well or something else. The wavefunction of two non-interacting particles is the product of the wavefunctions taking into account odd and even symmetry.
If it is truly two interacting electrons, the problem is more difficult and depends on the boundary conditions with other things involved. The "1-d hydrogen problem" is difficult enough, two mutually repelling particles is difficult at best. you then have to take into account spin etc...the fact that electrons are fermions cannot be neglected.
Please state the problem exactly from the text ot professors notes and I can give you some more ideas...
dt
the two electrons are fermions(electons),and they interact through coulomb force. i got this problem from my prof,saying this work could have some connections to entanglement and quantum dots.i wonder if we could throw the spin part away,just concentrate on the space part first!or have we consider it both at the same time?i have asked several profs about this problem,they all pointed out the main obstacle is the non-seperable variables!maybe we need some more advanced mathematical framework?likely the differential geometry
or...etc.
by the way,since i am a foreign guy,some corrections or instructions in my grammar will be highly wellcomed,that will make progress in my composition a lot!
best wishes
The electronic repulsion term (couloumbic force) is quite challenging. In fact, that term is one of the reasons that we are unable to solve the helium atom exactly. For this reason, I am not sure that your problem can be solved exactly.
I suppose your hamiltonian should be...
-h^2/2m*(d/dx1+d/dx2) + e^2/(4*pi*epsilon0*|r1-r2|)
In which case, how do you separate the last term? Like I said earlier, this is challenging. I would suggest you attempt approximation techniques. This is not a hard differential equation to solve numerically, but it is analytically.
Good luck.
I don't know how to solve this problem just like that, but I'd suggest the following approach. Because we know that the two electrons are confined to a finite interval, we know that their respective hilbert spaces in the space representation take on the following form:
psi_n(x) = N sin(n pi x / L)
The product hilbert space then has a basis psi_{n,m}(x,y) = psi_n(x) cross psi_m(y)
which we can represent by the dirac ket |n,m>.
If we ignore the fermionic part, in that basis, we can work out the hamiltonian from the coulomb interaction:
E_{k,l} + E_{m,n} + <k,l | 1/|x-y| | m,n>
the last term is an integral which I think can be worked out, and the first two E-terms are the free energy terms for the wave functions psi_n etc...
Now the final problem - which I don't know how to tackle - is how to diagonalise this infinite matrix.
If we want to introduce the fermionic character of the electrons, the modification is essentially that we should only consider anti-symmetric combinations (a redefinition of |k,l> as a function of the sine functions).
cheers,
Patrick.
I totally agree. That's what happens when I take a semester break from school. I hadn't solved it when I posted. I decided on a slightly different transformation, but I haven't worked through it yet. It makes the kinetric energt pretty messy. I tried to attach an image of the basic idea. It at least allows you to separate the potential (including the boundaries of the well). In equation form, the transformation that I have in mind is:
r = x - y
&theta; = arctan((a - y)/x)
These coordinates are not orthogonal, so, I'm a little discouraged. Notice that this is not the conventional r and &theta;.
  • · Replies 28 ·
  • · Replies 128 ·
15K
