Sources of gravitational fields
The discussion centers around the sources and sinks of gravitational fields, comparing them to electric fields, and exploring the behavior of antimatter in gravitational contexts. It includes theoretical considerations, implications of general relativity, and experimental observations related to matter and antimatter.
  • Some participants propose that mass is the source of the gravitational field, while others suggest that there is no "sink" for gravitational fields.
  • One participant highlights the differences between electric and gravitational fields, noting that gravitational fields behave as sinks for all mass.
  • Another participant suggests that the center of mass itself could be considered the source and sink of gravitational fields.
  • Questions are raised about the behavior of antimatter, specifically whether a neutral anti-hydrogen atom would fall or rise in a gravitational field.
  • Some participants argue that antimatter should behave similarly to matter under gravitational forces, referencing the equivalence principle in general relativity.
  • There is a discussion about the lack of experimental data on the gravitational interaction of antimatter, with some participants expressing uncertainty about whether antimatter falls with the same acceleration as ordinary matter.
  • One participant emphasizes the importance of keeping an open mind regarding the behavior of antimatter in gravity, noting that theoretical expectations have not yet been experimentally confirmed.
Participants express a range of views on the nature of gravitational fields and the behavior of antimatter, with no consensus reached on these topics. The discussion remains unresolved regarding the specifics of antimatter's interaction with gravity.
Limitations include the lack of experimental evidence for the gravitational behavior of antimatter and the dependence on theoretical frameworks that have not been conclusively tested.
lamp post
positive charges are sources of electric field and -ve charges are sink. what are sources and sink of gravitational fields?
Putting aside general relativity, I would say that mass is the "source" of the gravitational field. There is no "sink".
It's not that simple.
Poisson's equation for electrostatics (non-relativistic limit):
div E = +ρcharge
Poisson's equation for gravity (non-relativistic limit):
div g = -ρmass
Therefore, these are two fundamentally different types of fields. The electric one sources with respect to like particles and sinks WRT unlike particles. The gravitational one sinks WRT everything.
Mass is the source of the gravitational field
source and sink of gravitational field is the center of mass itself
What about anti-matter? Does a neutral anti-hydrogen atom (a hydrogen anti-atom? I mean a positron and anti-proton) fall to the floor of the chamber it's created in (somewhere in the CERN facilities, for example), or rise toward the ceiling (assuming other forces on the atom are balanced)?
To what extent has the gravitational interaction between matter and anti-matter been observed? What is the maximum deviation from theory consistent with the best experimental data? (or, how well do observations match predictions from theory?)
Nereid,
I believe that the equivalence of accelleration and gravity forces (the elevator tale) is part of the general relativity theory. Anti-matter should behave the same to acceleration forces as normal matter, hence it is predicted that anti-matter is also reacting normally on gravity.
This should answer your question:
http://math.ucr.edu/home/baez/physics/ParticleAndNuclear/antimatterFall.html
Antimatter is just matter. The name is misleading. E.g. Each particle has an antiparticle where antipartilc is defined as
a particle that has the same mass as another particle but has opposite values for its other properties; interaction of a particle and its antiparticle results in annihilation and the production of radiant energy.
It can't be said that one is matter and the other matter. It's really a matter of which one is discovered first
What experimental data is there on the gravitational interaction of anti-matter?
IIRC, quite a few of the other properties of anti-matter have been tested experimentally, but I don't recall seeing anything on observations of gravity.
That isn't really a meaningful question. E.g. suppose there are two particles A and B and the two form an anti-particle pair. By this it is mean that A is the anti-particle of B and B is the anti-partilce of A. Each has a well defined mass and it is that which is the source of gravity and it is that which responds to gravity. It is therefore not meaningul to call one matter and the other anti-matter. It's only an historical quirk that the particles have those names. Had the positron been discovered before he electron then it would be the electron which would have been called "anti-matter" and not not the anti-electron - aka positron. The electron might then a have been called the anti-positron.
See also
http://info.web.cern.ch/info/Press/PressReleases/Releases1996/PR01.96EAntiHydrogen.html
Thanks pmb and Andre.
I really liked the opening para in the first link you posted:
"In theory, antimatter dropped over the surface of the Earth should fall down. However, the issue has never been successfully experimentally tested. The theoretical grounds for expecting antimatter to fall down are very strong, so virtually all physicists expect antimatter to fall down -- however, some physicists believe that antimatter might fall down with a different acceleration than that of ordinary matter. Since this has never been experimentally tested, it's important to keep an open mind."
A sentence or three in the third para of the second are also good:
"If the behaviour of anti-hydrogen differed even in the tiniest detail from that of ordinary hydrogen, physicists would have to rethink or abandon many of the established ideas on the symmetry between matter and antimatter. Newton's historic work on gravity was supposedly prompted by watching an apple fall to earth, but would an "anti-apple" fall in the same way? It is believed that antimatter "works" under gravity in the same way as matter, but if nature has chosen otherwise, we must find out how and why."
No matter how solid we believe a theory is, we should always be looking for ways to test it further.
[Edit: added Andre (I hadn't realized that the Andre's and pmb's first link were the same :frown: ]
