| Thread Closed |
reflection grating |
Share Thread |
| Jan25-07, 05:11 PM | #1 |
| Jan25-07, 05:47 PM | #2 |
One thing I see is that when you found d you didn't convert from cm to m, so you have inconsistent units in your equation.
| Jan26-07, 09:58 AM | #3 |
d=.0005076cm = .000005076m
.000005076*sin(theta)=2*600e-9 sin(theta)=.0000012/.000005076 arcsin(.2364)=13.7º Anything else I'm missing, because the answer is not 13.7º? |
| Jan26-07, 10:15 AM | #4 |
reflection grating
Why do you have m=2? If it is first order I would think it would be m=1.
| Jan26-07, 11:37 AM | #5 |
Are you sure you are using the right equation? I think the grating equation you are using is not quite right for the conditions of your problem. The one you are using is a special case where the angle of incidence is normal to the grating. You need to include the angle of incidence in your equation. So your equation would be
d*(sin(theta(m)) - sin(theta(inc))) =m*lamda. where m = ±1 for first order maxima. Anyway see if that helps. |
| Thread Closed |
Similar discussions for: reflection grating
| How does a Reflection diffraction grating work? | General Physics | 10 | ||
| interference using a reflection grating: how to determine the slit width? | General Physics | 0 | ||
| diffraction grating | Advanced Physics Homework | 0 | ||
| Specular Reflection from a Reflection Diffraction Grating | General Physics | 1 | ||
| Reflection,Refraction,Total Internal Reflection,Diffraction | Introductory Physics Homework | 2 | ||
