Find Appropriate Angle for Forces in Free Body Diagrams
  • Thread starter Thread starter jjiimmyy101
    Angle Forces
The discussion revolves around understanding how to determine the appropriate angles for forces in free body diagrams, particularly in the context of physics problems involving objects like boxes and cars. Participants explore the relationships between different forces, such as normal, frictional, and gravitational forces, and their respective directions.
  • Participants discuss the general principles of force direction and the significance of angles in free body diagrams. There are inquiries about specific examples that cause confusion, as well as questions about the correct identification of angles in relation to surfaces and forces.
The conversation is active, with participants providing insights and clarifications regarding the angles of forces. Some have shared equations and methods for determining angles, while others express uncertainty and seek further clarification on specific points. There appears to be a collaborative effort to understand the problem better.
Some participants mention specific problems from a textbook, indicating that the discussion is grounded in particular examples. There are references to the need for clarity on notation and the relationships between different angles and forces, suggesting that assumptions about the problem setup are still being examined.
jjiimmyy101
When you draw a free body diagram of a box, car, collar, etc... and you put the normal force, frictional force, force of gravity and any other applicable forces, how do you know where the angle goes or maybe a better question would be how do you find an appropriate angle? I hope I'm making myself clear. Thanks in advance.
You'll probably need to give a specific example that causes you confusion.
In general, your knowledge of the physics tells you what direction the forces act. For example: gravity points toward the Earth (usually down), normal forces are normal (perpendicular) to the surfaces exerting them, frictional forces are parallel to the surfaces exerting them, etc.
Problem 13-80 is a good one to look at http://www.artsci.gmcc.ab.ca/courses/enph131oa/D4_More%20Tangential-Normal%20problems.mht
How do we know the angles are where they are shown to be?
Often a vector is situated at the center of gravity when an object's gravitation or momentum is concerned, or located at the point of application of a force (as to describe a torque), or multiple vectors can describe a field (such as an electromagnetic field) over a space.
An [horizontal] external force F on a block is balanced by a static frictional force S. As F is increased, S also increases, until S reaches a certain maximum value. The object then "breaks away," accelerating suddenly in the direction of F. If the block is now to move with constant velocity, F must be reduced [to 0] from the maximum value it had just before the block broke away.
Halliday/Resnick/Walker, Fundamentals of Physics, p. 99, Wiley 6th ed., 2001
[The vertical gravitational force and its reaction remain equal and opposite.]
Excuse me.
Your link at first glance seems fairly complete. What are you missing?
The link works
I'm not sure I understand your question. The normal force is always perpendicular to the surface. At the point B, the surface is horizontal (the slope of the tangent is zero) so the normal force acts vertically.
Restate your question.
(Oops: I read the wrong problem. Give me a minute.)
Are we looking at the same question? Problem 13-80 is on page 5. I think you're looking at page 1 problem 13-81?
Two equations, two unknowns.
Yep. I was looking at the wrong problem.
But now that I'm looking at the right problem, what's the problem?
The normal force is always perpendicular to the surface (and thus the curve). So the angle of the normal force can be figured out (it's not a variable). So can the angles θ and α. The only tricky part is what to use for "r": find the radius of curvature at that point.
I appreciate the help.
I think I'm understanding it more:) But how do you find á?
è = arctan(dy/dx)
The radius of curvature is easy to figure out too. [1+ (dy/dx)^2]^3/2/d2y/dx2
I don't understand your notation. What's "á" ?
è = arctan(dy/dx)
That's the angle of the tangent to the curve; the perpendicular is π/2 away. :smile:
Yep. (OK, not so tricky.)
oops, sorry.
I copied and pasted it, but ¨¢ is the angle between the force of the spring and the n-axis. How do you find it?
"theta = arctan(dy/dx)"
"That's the angle of the tangent to the curve; the perpendicular is ¦Ð/2 away."
So theta, from the equation above, would give me the angle between the t-axis and W. Right?
Sorry to keep wasting your time.
Here's how I'd find it. First find x & y coordinates of the point A. Then the angle the spring makes with the horizontal is arctan (y/x).
Theta (as defined above) is the angle of the tangent to the curve with respect to the horizontal. So... yes, you are right.
You're not wasting my time. I enjoy it. :smile:
Thank-you sooooooooooooooooooooooo much:)
I truly appreciate your assistance. You have been an extremely big help! I think I have enough information now to apply these concepts to other problems. Thanks for your help! I'll probably be back with more questions in the near future though...lol. Thank-you.
Excellent. Glad I could help.
