Thread Closed
Electric Potential Energy Question - Distance Between Charges and Ratio?
Share Thread Thread Tools
Jan28-07, 07:58 PM   #1
A positive charge +q1 is located to the left of a negative charge -q2. On a line passing through the two charges, there are two places where the total potential is zero. The first place is between the charges and is 4.00 cm to the left of the negative charge. The second place is 7.00 cm to the right of the negative charge. (a) What is the distance between the charges? (b) Find q1/q2, the ratio of the magnitudes of the charges.
2. Relevant equations
Not sure which one to use. the EPE one or kq1/x = kq2/d-x
3. The attempt at a solution
Ok...This might be one of the most confusing questions I've ever encountered in Physics! I drew a diagram, but i had no clue what i was doing. I know the equation V = Kq/r is supposed to be used, but i don't know what to substitute in the problem!!! please show me how you do this problem. appreciate all the help i can get! WHAT IS Q1 AND Q2??? my main problem
Book Answer: I only have part b, which is 3.67
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jan29-07, 05:31 AM   #2
Recognitions:
Homework Helper Homework Help
The only equation you need is
[tex]V = k \frac{q}{r}[/tex]
Some hints to solve the problem:
1. The total potential is the algebraic sum of the potentials as a result of the two charges.
2. A negative charge produces a negative potential while a positive charge results in a positive potential at a point (a positive test charge need to be pushed up against a positive charge).
3. You can eliminate k from the equations due to the fact that the sum is zero in both cases.
4. You can insert the distances in centimeters in the equations since the conversion factor, [tex]\times 10^{-2}[/tex], can be eliminated due to the fact that sum is zero.
5. Compare the ratios of the charges!
Mar4-10, 07:20 PM   #3
hey uhh can u tell me how u found the answer to part b?
Thread Closed
Thread Tools
Similar Threads for: Electric Potential Energy Question - Distance Between Charges and Ratio?
Thread Forum Replies
finding charges using electric field and distance Introductory Physics Homework 10
Electric Potential Energy Among Multiple Charges Advanced Physics Homework 13
Electric potential energy and point charges Introductory Physics Homework 1
Electric potential and electric potential energy question... Introductory Physics Homework 1
Electric Potential/Electric Potential Energy question... Introductory Physics Homework 3
