Thread Closed
CIRCUIT ANALYSIS: FInd the Thevenin equivalent of the circuit. 2 res - 1 IVS - 1 VCVS
Share Thread Thread Tools
Jan29-07, 12:13 AM   #1
Arrow
Find the Thevenin equivalent at terminals a-b of the circuit below.
2. Relevant equations
v = i R, KCL, KVL, [itex]R_{TH}\,=\,\frac{V_{OC}}{I_{OC}}[/itex].
3. The attempt at a solution
To get [itex]R_{TH}[/itex], I removed the independent voltage source and I added a test voltage of 1V, an unknown test current [itex]I_{OC}[/itex] and two KVL loops.
[tex]V_0\,=\,-1\,V,\,\,4\,V_0\,=\,-4\,V[/tex] <----- Right?
For KVL Loop 1)
[tex]10000\,I_1\,+\,(1\,V)\,=\,0[/tex]
[tex]I_1\,=\,-\frac{1}{10000}\,A\,=\,-0.0001\,A[/tex]
For KVL Loop 2)
[tex](-1\,V)\,+\,20000\,I_2\,+\,4\,V_0\,=\,0[/tex]
[tex]I_2\,=\,\frac{5}{20000}\,A\,=\,0.00025\,A[/tex]
KCL at node between two resistors)
[tex]I_1\,+\,I_{OC}\,=\,I_2\,\,\longrightarrow\,\,I_{OC}\,=\,I_2\,-\,I_1[/tex]
[tex]I_{OC}\,=\,(0.00025\,A)\,-\,(-0.0001\,A)\,=\,0.00035\,A[/tex]
Now I use the equation mentioned above for [itex]R_{TH}[/itex] to get the Thevenin equivalent resistance)
[tex]R_{TH}\,=\,\frac{(1\,V)}{0.00035\,A}\,\approx\,2857\Omega[/tex]
Now I need to get the Thevenin equivalent voltage at the terminals a-b. I redrew the circuit to include the 70V independent voltage source and added two node voltages.
[tex]V_0\,=\,70\,-\,V_1,\,\,V_2\,=\,4\,V_0[/tex] <----- Right?
[tex]V_2\,=\,4\,V_0\,=\,4\,(70\,-\,V_1)\,=\,280\,-\,4\,V_1[/tex]
KVL Loop 1)
[tex](-70\,V)\,+\,V_0\,+\,V_{TH}\,=\,0[/tex]
[tex]V_1\,-\,V_{TH}\,=\,70[/tex]
KVL Loop 2)
[tex]-V_{TH}\,+\,V_1\,+\,V_2\,=\,0[/tex]
[tex]3\,V_1\,+\,V_{TH}\,=\,280[/tex]
Now I have two equations in two variables and I can solve. I get [itex]V_1\,=\,87.5\,V[/itex] and [itex]V_{TH}\,=\,17.5\,V[/itex]. But wouldn't the Thevenin equivalent voltage include the contributions from both sources? (i.e. - [itex]V_{TH}[/itex] is actually [itex]V_1[/itex], [itex]V_{TH}\,=\,87.5\,V[/itex] and not [itex]V_{TH}\,=\,17.5\,V[/itex])
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan29-07, 09:19 AM   #2
Does the [itex]R_{TH}[/itex] look correct? Shouldn't [itex]V_1[/itex] and [itex]V_{TH}[/itex] be equal?
Sep13-08, 05:01 AM   #3
CEL
Quote by VinnyCee View Post
For KVL Loop 1)
For KVL Loop 2)
KVL Loop 1)
KVL Loop 2)
In the equation for loop 1 you have made a wrong substitution. You should have
[tex]V_1\,-\,V_{TH}\,=\,0[/tex]
instead of
Of course this leads to [itex]V_{TH}=V_1[/itex]
Thread Closed
Thread Tools
Similar Threads for: CIRCUIT ANALYSIS: FInd the Thevenin equivalent of the circuit. 2 res - 1 IVS - 1 VCVS
Thread Forum Replies
CIRCUIT ANALYSIS: Non-Inverting Ideal OpAmp, 2 resistors, 1 IVS - Find Thevenin Equiv Introductory Physics Homework 4
CIRCUIT ANALYSIS: Non-Ideal OpAmp with 2 resistors - Find Thevenin Equivalent Introductory Physics Homework 1
CIRCUIT ANALYSIS: Find the Thevenin equivalent of transistor model - CCCS, IVS, 2 res Introductory Physics Homework 13
CIRCUIT ANALYSIS: 7resistors & 1 I.V.S. - Find equivalent resistance and current Engineering, Comp Sci, & Technology Homework 5
CIRCUIT ANALYSIS: Find the equivalent resistance seen by the source Engineering, Comp Sci, & Technology Homework 1
