Limits of Arc Tangent (a) and (b)
  • Thread starter Thread starter SheldonG
    Arc Limit Tan
The discussion revolves around evaluating limits involving the arctangent function, specifically: a) the limit of (arctan x)/x as x approaches 0, and b) the limit of (arctan(x) - pi/4)/(x-1) as x approaches 1. Participants explore the properties of the arctangent function and its derivatives in the context of these limits.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to rewrite the limits using substitutions related to the arctangent function and explores various algebraic manipulations. Some participants suggest using L'Hôpital's Rule for the second limit, while others express a desire to find a solution without it. There is also mention of using power series expansions for arctan(x) as a potential approach.
The discussion is active, with participants offering different methods and considerations. Some guidance has been provided regarding the use of L'Hôpital's Rule and power series, but there is no explicit consensus on the best approach to take without it. The original poster is seeking further suggestions while acknowledging the insights shared.
Participants note that the original poster's textbook has not yet covered L'Hôpital's Rule, which influences the direction of the discussion. There is also an emphasis on understanding the definitions of derivatives in relation to the limits being evaluated.
SheldonG
Evalute:
a) lim (x->0) (arctan x)/x
b) lim (x->1) (arctan(x) - pi/4)/(x-1)
Inverse tangent, trig identities. Kline's calculus, which I am teaching myself from, does not have that much detail on limits.
For (a), I solved it fairly easily. I used y = arctan(x), x = tan(y) to rewrite the limit as
y/tan(y) = y/(sin y/cos y) = y(cosy)/sin y) = (y/sin y)(cos y).
as x->0, y/sin y = 1, as does cos(y).
Applying the same approach to (b) has not rewarded me with a solution.
Making the same substition y = arctan(x), x=tan(y), I get
(y - pi/4)/(tan(y) - 1)
(4y - pi)(cos y)/(4(sin y - cos y))
But I don't seem to be able to find my way to a solution.
Some things I have tried:
trig identities like -cos(2a) = sin^2 y - cos^2 y, as well as others.
I tried dividing up the fraction, and computing the sums:
y/(sin y - cos y) - pi/(sin y - cos y).
I also tried finding the limit of the difference between this and part (a), on the assumption that the limit of the sums is the sum of the limits.
If anyone could prod this old guy in a useful direction, it would be appreciated.
Thanks,
Sheldon
when x->1, top and bottom goes to zero, can use l'hopital rule
Thanks mjsd, but the book hasn't covered that yet.
Well then this is a good time to learn. l'hospital's Rule is very useful to apply to limits. Basically, if by direction substitution you get 0/0, infinity/infinity or some other indeterminate forms, then you can use this method.
Say your limit is x>C f(x)/g(x), where C is some number. If we get an inderterminate form, the limit is equal to x>C f'(x)/g'(x). We just took the derivative of the top and bottom. Then we try substituting again. That is what out original limit is equal to. If it doesn't work, and we get another indeterminatite form, use the rule again and again til it works.
Hi Gib Z.
Perhaps this would be a good time to learn... But working on the assumption that it is solvable without l'hospital's Rule, I wonder if anyone has any other suggestions?
Thanks for your advice,
Sheldon
Maybe using the power series for arctan (x) would be useful here.
arctan x = x - x^3/3 + x^5/5 - ...
Part b is just the definition of derivative for arctan (x) at x=1.
d/dx (arctan x) = (1+x^2)^-1
EDIT: part a is also the definition of derivative for arctan(x) at x=0. It should be more clear if you write it as [arctan(x)-0]/(x-0).
Ah, thank you, Derek. I should have seen that. That makes sense. So I can say that
(arctan(x) - pi/4)/(x-1) = (arctan(x) - arctan(pi/4))/x - 1
so it would follow right away that the limit is the same as the derivative of (b), which gives me 1/2. Wonderful. Thank you so much.
Sheldon
  • · Replies 40 ·
