Hermitian Operator: AB Hermitian if [A,B]=0
The discussion revolves around the properties of Hermitian operators, specifically examining the conditions under which the product of two Hermitian operators, A and B, is also Hermitian. The original poster seeks guidance on how to demonstrate that the product AB is Hermitian only if the commutator [A, B] equals zero.
  • Participants explore various mathematical properties and definitions related to Hermitian operators, including the use of scalar products and adjoint operators. Some suggest starting with the properties of the commutator and the implications of the operators being Hermitian. Others raise questions about the domains of the operators involved and the implications of boundedness.
The discussion includes multiple lines of reasoning, with some participants providing detailed mathematical arguments while others question the assumptions made. There is no explicit consensus, but several participants offer insights that could guide further exploration of the problem.
Some participants note the importance of specifying the domains of the operators A and B, as well as the implications of their Hermitian properties. There is also mention of the potential for non-Hermitian operators to have real spectral values, which adds complexity to the discussion.
alisa
show that if A and B are both Hermitian, AB is Hermitian only if [A,B]=0. where or how do io start?
From the property (AB)+=B+a+
+ denoting hermitian conjugation
Expand [A,B]=0, then use the hint above.
Here's how i'd do it. Consider the scalar product
[tex]\langle x, AB y\rangle[/tex] (1)
for "x" unspecified yet and [itex]y\in D(AB), \overline{D(AB)}=\mathcal{H}[/itex] an arbitrary element.
[tex]\langle x, AB y\rangle = \langle x, A^{\dagger}B y\rangle[/tex] (2)
,where [itex]D(A^{\dagger}B)=D(AB)[/itex], since [itex]D(A)\subseteq D\left(A^{\dagger}\right)[/itex]
[tex]\langle x, A^{\dagger}B y\rangle =\langle x, A^{\dagger}B^{\dagger} y\rangle[/tex] (3)
as [itex]B\subseteq B^{\dagger}[/itex]. Therefore [itex]y\in D\left(A^{\dagger}B^{\dagger}\right)[/itex] and [itex]D(AB)\subseteq D\left(A^{\dagger}B^{\dagger}\right)[/itex].
[tex]\langle x, A^{\dagger}B^{\dagger} y\rangle =\langle Ax, B^{\dagger} y\rangle[/tex] (4),
if [itex]x\in D(A)[/itex].
[tex]\langle Ax, B^{\dagger} y\rangle =\langle BAx, y\rangle[/tex] (5),
if [itex]x\in D(BA)\subseteq D(A)[/itex].
[tex]\langle BAx, y\rangle=\langle ABx, y\rangle[/tex] (6),
since, by hypothesis [itex]AB=BA[/itex].
Finally
[tex]\langle ABx, y\rangle =\langle x, \left(AB)^{\dagger}y\rangle[/tex](7)
by the definition of the adjoint. Therefore [itex]y\in D\left((AB)^{\dagger}\right)[/itex] and
[tex]ABy=(AB)^{\dagger} y {} \wedge D(AB)\subseteq D\left((AB)^{\dagger}\right)[/tex] (8),
which means the operator AB is symmetric/hermitean.
QED.
Finally
QED.
wouldn't it be easier to just say that x,y are in the domain of the operators A, B (which i agree IS important to state, as is actually applying the operator to an element as opposed to treating it as some "algebraic" quantity as many books do)? in which case the proof would reduce to about 4 lines. in other words, when would the domain of A and its hermitian conjugate NOT be the same?
Dear alisa, Does it go like this?
Let |n> be an eigenstate of A and B. Then:
AB|n> = Abn|n> = bn.an|n>.
Therefore AB is hermitean because bn.an is real.
In a similar expansion you will find that: [A, B]|n> = 0.
So, given |n>, AB is hermitean and [A, B] = 0.
This should point you in the right direction; check it out, wm
I don't know about that. I don't claim that my proof is unique/the shortest possible.
By the Hellinger-Toeplitz theorem, iff the operator A is bounded. My proof accounts for the arbitrary character of the A and B operators.
The spectrum of a hermitean operator is not necessarily real. Actually only the eigenvalues (points in the pure point spectrum) are real, however, one cannot guarantee that [itex]|n\rangle[/itex] is an element of the Hilbert space. Therefore one cannot guarantee that "a_{n}b_{n}" is real. And even if it was real, there are examples of nonhermitean operators with real spectral values.
Dear dextercioby, At alisa's level I thought it might go like this:
Let
(1) A|x> = a|x>. If A is hermitean then (by definition):
(2) <x|A|x> = <x|A|x>*. Substituting (1) into (2):
(3) <x|a|x> = <x|a|x>*; ie,
(4) a<x|x> = a*<x|x>; ie,
(5) a = a*; ie, a is real (zero being excluded as trivial).
Thus, in the example that I gave: bn.an is real (because each factor is real).
Would that be satisfactory at alisa's level? wm
I don't know Alisa's level of education. And in this case i'd rather make no assumption, unlike you.
Dear dextercioby, With alisa's best interests in view, may I suggest that you alert her to the ''level of education'' at which my analysis fails?
Thanks; and best regards, wm
Your analysis is mathematically faulty. At best it can be considered a heuristic approach with made with disputable arguments. But this is already off-topic, so i'd say "let's drop it".
  • · Replies 17 ·
12K
