Converting Mass to Light: The Possibility of Increasing Particle Energy
  • Context: Undergrad
  • Thread starter Thread starter Joza
    Light Mass
The discussion centers around the theoretical possibility of converting mass into light, specifically exploring whether particles with mass can be transformed into photons and the implications of such a transformation for concepts like speed and energy. The conversation touches on fundamental physics concepts, particle interactions, and the nature of light and matter.
  • Some participants propose that photons are high-energy waves and question whether it is theoretically possible to increase the energy of a massive particle to convert it into a photon.
  • Others argue that a particle with mass cannot reach the speed of light, as it would require an infinite amount of energy, thus only massless particles can travel at that speed.
  • A participant mentions that the energy of a photon is related to its frequency, and discusses the annihilation of particles and antiparticles, which produces photons while conserving energy-mass.
  • One participant suggests that if a spacecraft's mass could be converted to light, it would be able to travel at the speed of light and be free from gravitational forces, questioning the plausibility of this idea.
  • Another participant counters that if a spacecraft were turned into light, it would no longer retain its identity as a spacecraft, emphasizing the fundamental differences between light and matter.
  • There is a discussion about the possibility of reversing the process, where light could be converted back into mass, referencing pair production as a phenomenon where a photon can create a particle and its antiparticle under certain conditions.
  • One participant encourages further study of Maxwell's equations and emphasizes the importance of equations in understanding physics.
Participants express a range of views on the conversion of mass to light and vice versa, with no clear consensus reached. Some concepts are debated, and various interpretations of physical principles are presented without resolution.
Participants express uncertainty regarding the fundamental nature of light and matter, the implications of energy conservation, and the mathematical frameworks that govern these phenomena. There are references to concepts like pair production and Maxwell's equations, which may require further exploration for clarity.
Joza
I am only completing high school physics, but I hope to study physics at university, so bear my level of knowledge in mind!
I understand that at the most fundamental level, matter is just a low frequency wave. Photons, or light, are very high energy waves. Would it be theoretically possible to some how increase the energy of a particle with mass and turn it into a photon?
I don't know whether there is a major flaw in that or whether even my statements are entirely correct!
Any input would be great!
Well a photon always travels at the speed of light and it has no rest mass. The problem here is that a particle with mass cannot be accelerated to attain the speed at which photons travel. This is because as the particle gets closer and closer to the speed of light, more and more energy must be expended to increase its velocity by very small amounts. Hence an infinite amount of energy would be needed to achieve the speed of light. Summing it up, only massless particles can travel at the speed of light.
BTW, the energy of a photon is related to its frequency. So it depends on your concept of "high energy". For instance, gamma rays, which have very energetic photons (high frequency), have very high energy levels.
However if you are talking about the collisions of particles, it happens for example when a particle and its anti-particle collide and annihilate each other. Both of these particles have mass and because of the conservation of energy-mass, the mass can't just simply vanish. Instead it is converted to energy. For instance when a electron and its anti-particle (positron) collide, they annihilate each other and in the process, photons are created.
Hi Joza, just how light turns into matter/anti-matter is not understood at present.
Incidentally, matter is a very high frequency wave. The frequency of a slow electron's phase is about 10^50 Hz. An electron's 'size' is also many magnitudes
smaller than the wavelength of the light that may produce it.
If I'm wrong on any of these points, I'm sure someone will correct me.
M
In a nutshell, what I'm getting at here is this:
If somehow, the mass of a spacecraft could be turned into light, it would be able to travel at the speed of light and also be free from G forces etc. because it has no mass.
Is this at all plausible?
If you turned your spacecraft to light it wouldn't be a spacecraft anymore.
Light and matter are completely different things.
Study Maxwell's equations.
Thats true, but could it then be reversed and light goes back to mass? I have not encountered Maxwell's equations yet.
It would do you some good to read on pair production. This is the creation of a particle and its anti-particle from a photon without violating the conservations laws. The photon must have enough energy for the particle rest mass energy.
http://en.wikipedia.org/wiki/Pair_production
Hi Joza,
it is good to be imaginative and ask lots of questions, but in the end physics is equations. The answers, such as they are, lie there. You have much to look forward to.
M
  • · Replies 21 ·
  • · Replies 35 ·
