Evaluating Integrals Using Residues and Proving Complex Analysis Equations
This discussion focuses on evaluating integrals using residue theory in complex analysis. The integrals include \int _0 ^{\infty} \frac{x^{1/4}}{1 + x^3}dx, \int _{-\infty} ^{\infty} \frac{\cos (x)}{1 + x^4}dx, and \int _{-1} ^1 \frac{dx}{(x-A)\sqrt{1-x^2}}, where A is a complex constant outside the interval [-1,1]. The discussion highlights the use of residues, particularly in calculating integrals involving poles and singularities, and emphasizes the importance of understanding analytic functions and contour integration.
  • Complex analysis fundamentals, including residue theory
  • Understanding of analytic functions and singularities
  • Familiarity with contour integration techniques
  • Knowledge of evaluating integrals involving trigonometric functions and polynomials
  • Study the application of the residue theorem in complex analysis
  • Learn how to compute residues for functions with simple poles
  • Explore advanced techniques in contour integration
  • Investigate the properties of Fourier transforms and their relation to complex integrals
Students and professionals in mathematics, particularly those studying complex analysis, as well as physicists and engineers who apply these concepts in fields such as signal processing and fluid dynamics.
AKG
1. Evaluate the following integrals using residues:
a)
[tex]\int _0 ^{\infty} \frac{x^{1/4}}{1 + x^3}dx[/tex]
b)
[tex]\int _{-\infty} ^{\infty} \frac{\cos (x)}{1 + x^4}dx[/tex]
c)
[tex]\int _0 ^{\infty} \frac{dx}{p(x)}[/tex]
where p(x) is a poly. with no zeros on {x > 0}
d)
[tex]\int _{-\infty} ^{\infty}\frac{\sin ^2(x)}{x^2}dx[/tex]
2. Let A be a complex constant lying outside the real interval [-1,1]. Using residues, prove that:
[tex]\int _{-1} ^1 \frac{dx}{(x-A)\sqrt{1-x^2}} = \frac{\pi }{\sqrt{A^2 - 1}}[/tex],
with the appropriate determination of [itex]\sqrt{A^2 - 1}[/itex].
Let f(z) be analytic except for isolated singularities aj in a region [itex]\Omega[/itex]. Then
[tex]\frac{1}{2\pi i}\int _{\gamma }f(z)dz = \sum _j n(\gamma , a_j)\mbox{Res} _{z=a_j}f(z)[/tex]
for any cycle [itex]\gamma[/itex] which is homologous to zero in [itex]\Omega[/itex] and does not pass through any of the points aj.
1.a) I made the substitution z = x1/4, giving:
[tex]\int _0 _{\infty} \frac{x^{1/4}}{1 + x^3}dx[/tex]
[tex]= 4\int _0 ^{\infty} \frac{z^4}{1 + z^{12}}dz[/tex]
[tex]= 2\int _{-\infty} ^{\infty} \frac{z^4}{1 + z^{12}}dz[/tex]
[tex]= 4\pi i\sum _{\mbox{Im} (z) > 0}\mbox{Res}f(z)[/tex]
I know how to give expressions for these residues, but I don't know a good way to compute this thing. I've used rotationaly symmetry to express this as (a sum of 6 things) times (one of the residues) but it's still ugly.
b)
[tex]\int _{-\infty} ^{\infty} \frac{\cos x}{1 + x^4}dx[/tex]
[tex]= \mbox{Re}\left (\int _{-\infty} ^{\infty} \frac{e^{ix}}{1 + x^4}dx \right )[/tex]
[tex]= \mbox{Re}\left (2\pi i \sum _{\mbox{Im} (z) > 0} \mbox{Res} \frac{e^{iz}}{1 + z^4} \right )[/tex]
I know the relevant poles are [itex]e^{3i\pi /4}[/itex] and [itex]e^{i\pi /4}[/itex], so I know how to find expressions for the residues at these poles, but again I don't have a neat way to compute this.
c) If p is constant or linear, the integral doesn't exist. Otherwise, the integral does exist, but I have no clue really how to compute it for arbitrary p.
d) Again, not much clue.
2. Well I can compute that the residue at A is (1 - A2)-1/2. It's a matter of making a clever choice of arc over which to integrate, or possibly a parametrized family of arcs and then taking the limits as the parameters of the family tend to desired limits, but I can't see what this clever choice would be. Any hints?
I would think that for c the integral would evaluate to zero, since there are no residues in the interval you're integrating over, but I'm not absolutely certain that that is correct.
EDIT: On second thought that probably isn't correct because to me the question seems to imply that the polynomial only has no zeros only on the positive real line since they specify x>=0 and you can't give complex numbers that order. So if the polynomial has any complex zeros the best answer I think you could give would be 2*pi*i*Sum(x_i) where x_i are all the complex zeroes of the polynomial... But then if the polynomial is real, we should be expecting a real answer so you would probably want only the really part of that which again I have a feeling should turn out to e zero.
I'm sorry if this doesn't help you very much, I can't remember very much from my complex analysis course, but that problem interested me, and maybe some of this might help.
I'll do one for you in full...(PF willing)... the rest should be similar... these are tedious but method is generally clear.
[tex]\displaystyle{\int_{-\infty}^\infty \frac{\cos (az)}{z^4+1}\; dz}[/tex]
[tex]\displaystyle{=\lim_{R\rightarrow \infty}\int_\text{loop} - \int_\text{upper arc}, a>0}[/tex]
it can be easily shown that
[tex]\displaystyle{\int_\text{upper arc}\rightarrow 0}[/tex] as [tex]R\rightarrow \infty[/tex] since
[tex]\displaystyle{\left|\frac{e^{iz}}{z^4+1}\right| \leq \left|\frac{1}{z^4+1}\right| \leq \left|\frac{1}{R^4-1}\right| \sim \frac{1}{R^4}}[/tex] and so ML-estimate gives function to go like
[tex]\displaystyle{\frac{1}{R^4}.\pi R \sim \frac{1}{R^3}}[/tex] and integral vanish as R goes to infinity.
So, we want Real part of
[tex]\displaystyle{\int_\text{loop} \frac{e^{iaz}}{z^4+1}\; dz=2\pi i \left( \text{Res}\left[\frac{e^{iaz}}{z^4+1}, e^{i\pi/4}\right]+\text{Res}\left[\frac{e^{iaz}}{z^4+1}, e^{i3\pi/4}\right]\right)}[/tex]
Residues can be evaluated using
[tex]\displaystyle{\text{Res}\left[f(z)/g(z), z_0\right]=\frac{f(z_0)}{g'(z_0)}}[/tex] where at [tex]z_0, g(z)[/tex] has a simple zero, [tex]g'(z)[/tex] is the derivative.
therefore, we have
[tex]\displaystyle{\int_\text{loop} \frac{e^{iaz}}{z^4+1}\; dz=<br /> 2\pi i \left[\frac{e^{ia e^{i\pi/4}}}{4(e^{i 3\pi/4})}+<br /> \frac{e^{ia e^{i 3\pi/4}}}{4(e^{i 9\pi/4})}\right]}[/tex]
after some quick manipulation using Euler formula:
[tex]\displaystyle{= \frac{\pi i}{2} e^{-a/\sqrt{2}}\left(<br /> e^{i(a/\sqrt{2}-3\pi/4)}+ e^{-i(a/\sqrt{2}+\pi/4)} \right)}[/tex]
convert [tex]i \rightarrow e^{i\pi/2}[/tex] and multiply into bracket, it becomes
[tex]\displaystyle{= \frac{\pi}{2} e^{-a/\sqrt{2}}\left(<br /> e^{i(a/\sqrt{2}-\pi/4)}+ e^{-i(a/\sqrt{2}-\pi/4)} \right)}[/tex]
[tex]\displaystyle{= \pi e^{-a/\sqrt{2}} \cos (a/\sqrt{2}-\pi/4)}[/tex]
[tex]\displaystyle{= \pi e^{-a/\sqrt{2}} (\cos (a/\sqrt{2})\cos (\pi/4)<br /> +\sin (a/\sqrt{2})\sin (\pi/4))}[/tex]
so altogether you get
[tex]\displaystyle{\int_{\infty}^{\infty} \frac{\cos(az)}{z^4+1}\; dz<br /> = \frac{\pi}{\sqrt{2}}e^{-a/\sqrt{2}}\left[\cos(a/\sqrt{2})+<br /> \sin(a/\sqrt{2})\right], a>0}[/tex]
NB: this is a standard textbook problem, so don't charge me for posting full solutions to Homework Forum :smile:
  • · Replies 105 ·
13K
  • · Replies 47 ·
