Cylindrical Shells and Gauss' Law
The discussion centers on calculating the electric field generated by an infinitely long cylindrical shell and an infinitely long cylinder. For the cylindrical shell with a radius of 6.0 cm and a surface charge density of 12 nC/m², the electric field at a radius of 5.9 cm is definitively zero, as the charge is uniformly distributed on the surface. In contrast, for the cylinder with a radius of 4.0 cm and a volume charge density of 200 nC/m³, the electric field at a radius of 8.0 cm is calculated using the formula E = (rho*R²)/(r*epsilon_0), resulting in an electric field of approximately 452 N/C.
  • Understanding of Gauss' Law
  • Familiarity with electric field calculations for cylindrical geometries
  • Knowledge of surface and volume charge densities
  • Proficiency in using the permittivity of free space (epsilon_0)
  • Study the application of Gauss' Law in different geometries
  • Learn about electric field calculations for non-uniform charge distributions
  • Explore the concept of electric flux and its relation to electric fields
  • Investigate the effects of charge distribution on electric field strength
Students studying electromagnetism, physics educators, and anyone involved in electrical engineering or physics research focusing on electric fields and charge distributions.
Soaring Crane
An infinitely long cylindrical shell of radius 6.0 cm carries a uniform surface charge density sigma = 12 nC/m^2. The electric field at r = 5.9 cm is approximately
a.0.81 kN/C
b.zero.
c.1.3 kN/C.
d.12 kN/C.
e.0.56 kN/C.
See below.
Will the correct choice be b. 0? I am assuming that this is a conducting cylindrical shell. When r < R, E will be 0.
An infinitely long cylinder of radius 4.0 cm carries a uniform volume charge density rho = 200 nC/m^3. What is the electric field at r = 8.0 cm?
a.0.23 kN/C
b.0.11 kN/C
c.57 kN/C
d.0.44 kN/C
e.zero
electric flux = Integral [E*dA] = Q_enclosed/epsilon_0
I sloshed through this one because I mixed up the radii (r and R) at first. Did I eventually get the correct answer?
Q_enclosed = rho*2*pi*R^2*l
flux = E*2*pi*r*l
E*2*pi*r*l = (rho*2*pi*R^2*l)/(epsilon_0)
E = (rho*R^2)/(r*epsilon_0) = (200*10^-9 c/m^3)(0.04 m)^2/[0.08 m*8.85*10^-12] = 452 N/C??
Thanks.
a.0.81 kN/C
b.zero.
c.1.3 kN/C.
d.12 kN/C.
e.0.56 kN/C.
See below.
No reason to think the shell has any thickness or that it's a conductor. Nonetheless, since the charge is on the surface of the shell (and we presume no other charge exists) the field will be zero for r < R. (Since the charge enclosed within any cylindrical shell with such a radius would be zero.)
a.0.23 kN/C
b.0.11 kN/C
c.57 kN/C
d.0.44 kN/C
e.zero
flux = E*2*pi*r*l
I didn't check your arithmetic, but your method is correct.
