What Are the Characteristics and Effects of Electromagnetic Forces and Fields?
  • Thread starter Thread starter nautica
    Set
The discussion focuses on the characteristics and effects of electromagnetic forces and fields, specifically through the analysis of an LC circuit, magnetic fields produced by moving charges, and the calculation of forces between parallel current-carrying wires. The oscillation frequency of an LC circuit with a 1 microFarad capacitor and a 4 mH inductor is calculated to be approximately 250 Hz. The magnetic field generated by electrons moving in a counterclockwise direction is directed out of the page. Additionally, the units of motional emf are defined as volt/second, and the attractive force per unit length between two parallel wires carrying currents of 2 A and 4 A is calculated to be 1.6 x 10^-3 N/m.
  • Understanding of LC circuits and their oscillation frequency calculations
  • Knowledge of magnetic fields produced by electric currents
  • Familiarity with the concept of motional electromotive force (emf)
  • Ability to apply formulas for calculating forces between parallel current-carrying wires
  • Study the derivation and applications of the formula for oscillation frequency in LC circuits
  • Explore the right-hand rule for determining the direction of magnetic fields
  • Investigate the principles of motional emf and its applications in electromagnetic induction
  • Learn about the implications of Ampère's Law in calculating forces between current-carrying conductors
Students and professionals in physics, electrical engineering, and anyone interested in understanding the principles of electromagnetism and its practical applications in circuit design and analysis.
nautica
19) An LC circuit consist of a 1 microFarad capacitor and a 4 mH inductor. Its oscillation frequency is approximately:
21) Electrons are going around a circle in a counterclockwise direction. At the center of the circle they produce a magnetic field that is:
Out of the page.
23) the units of motional emf are
a) volt/second
b) volt meter/second
c) volt/tesla
d) tesla/second
e) tesla meter squared/second
24) two parallel wires, 4 cm apart, carry currents of 2 A and 4 A respectively, in opposite directions. the force per unit length in N/m of one wire on the other is
a) 10^-3 repulsive]
b) 10^-3 attractive
c) 4x10^-5 replusive
d) " attractive
e) none
26 Units of magnetic field might be?
a) C m/s
b) C s/m
c) C/kg
d) kg/C s
e) N/C m
Thanks again
Nautica
[tex]f= \frac{1}{\sqrt{LC}}[/tex]
19) The oscillation frequency of this LC circuit can be calculated using the formula f = 1/(2π√(LC)). Plugging in the values of C = 1 microFarad and L = 4 mH, we get f = 1/(2π√(1 microFarad x 4 mH)) = 1/(2π√(4 x 10^-9)) = 1/(2π x 2 x 10^-3) = 1/(4π x 10^-3) = 250 Hz. Therefore, the oscillation frequency of this LC circuit is approximately 250 Hz.
21) The magnetic field produced by the electrons going around a circle in a counterclockwise direction will be out of the page. This is because the direction of the magnetic field is perpendicular to the direction of the current flow, and in this case, the current flow is in the counterclockwise direction.
23) The units of motional emf are volt/second. This is because motional emf is the induced voltage in a conductor moving through a magnetic field, and voltage is measured in volts and time is measured in seconds.
24) The force per unit length of one wire on the other can be calculated using the formula F = μ0I1I2/(2πd), where μ0 is the permeability of free space, I1 and I2 are the currents in the two wires, and d is the distance between the wires. Plugging in the values of μ0 = 4π x 10^-7 N/A^2, I1 = 2 A, I2 = 4 A, and d = 4 cm = 0.04 m, we get F = (4π x 10^-7 N/A^2) x (2 A) x (4 A)/(2π x 0.04 m) = 1.6 x 10^-3 N/m. This force per unit length is attractive, as the currents in the two wires are in opposite directions.
26) The units of magnetic field can be expressed as tesla (T), which is equivalent to N/(A x m) or kg/(A x s^2). Therefore, option c) C/kg is the correct answer.
  • · Replies 16 ·
  • · Replies 25 ·
