Another question on ranks (linear algebra).
The discussion revolves around proving a property of square matrices in linear algebra, specifically that the rank of the product of a matrix and its transpose, \( AA^t \), is equal to the rank of the original matrix \( A \). Participants explore the relationship between the ranks and the implications of solutions to the equations involving these matrices.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the need to demonstrate that if \( x \) is a solution of \( AA^tx=0 \), then \( x \) must also be a solution of either \( Ax=0 \) or \( A^tx=0 \). Some suggest using definitions and methods like Gauss elimination, while others propose leveraging the singular value decomposition (SVD) of \( A \) to show the relationship between ranks.
The discussion is active, with various approaches being considered. Some participants express skepticism about certain methods, particularly regarding proof techniques like proof by contradiction versus counterexamples. There is no explicit consensus, but several lines of reasoning are being explored, indicating a productive exchange of ideas.
Participants are navigating the complexities of linear algebra proofs, particularly around the definitions of rank and null space. There is an acknowledgment of the potential for different proof strategies, including those that may rely on advanced concepts like singular value decomposition.
MathematicalPhysicist
i need to prove that for A square matrix: rank AA^t=rank A.
well rank AA^t<=rank A, but how do i show that rankAA^t>=rankA, i mean i need to show if x is a solution of AA^tx=0 then x is a solution of Ax=0 or of A^tx=0, but how?
You are trying to show that the transpose of an nxn multiplied by itself has the same or less rank? I would use the definition of matrix multiplication, and then transpose, and do Gauss elimination (probably on a 2x2). There may be a more subtle way, but the forceful approach should work.
Let U = {x : AA^t x = 0}, and V = {x : A^t x = 0}. Assume you have already shown that dim V <= dim U (which implies r(A) >= r(AA^t) ), and now assume dim U > dim V (which would imply r(A) > r(AA^t) ) and find a counterexample (it's simple). When you have shown that dim U > dim V can't hold, then dim U = dim V must hold, and hence r(A^t) = r(A) = r(AA^t). Hope this works.
i don't think this would work, cause in ad absurdum proofs you need to get a logical contradiction, not a counter example, perhaps I am wrong here and you are right, but i don't think so.
Actually, that's what's bothering me, too. If we assume it holds for any matrix, could a 'proof by counterexample' work? Guess some of the PF mathematicians should take over on this one.
You can show this directly from the singular value decomposition of A.
Let the SVD of A be U.D.V^T where D is the diagonal matrix of singular values. Write the SVD of A.A^T in terms of U D and V, and show that A and A.A^T have the same number of zero singular values, hence the same rank.
There is a similar proof involving eigenvalues and eigenvectors.
There is probably a similar but more "elementary" proof involving choosing a set of basis vectors where a subset of the basis vectors spans the null space of A - but I haven't thought idea that right through.
  • · Replies 18 ·
