What is the flaw in this logic?
  • Thread starter Thread starter Izzhov
    Logic
The discussion revolves around the validity of a reasoning process that equates the expression for \(x^2\) as a sum of \(x\) added \(x\) times, and subsequently examines the implications of differentiating this expression. Participants are exploring the nuances of calculus, particularly the rules of differentiation and the assumptions underlying them.
  • Participants are questioning the validity of treating \(x^2\) as \(x\) added \(x\) times and whether this holds for all values of \(x\). Some are attempting to apply the definition of the derivative to challenge the initial reasoning, while others are discussing the implications of using the derivative of sums and the product rule.
The conversation is ongoing, with various interpretations being explored. Some participants have offered insights into the nature of the sums involved and the conditions under which derivative rules apply, while others express confusion about the reasoning presented. There is no explicit consensus, but several productive lines of inquiry have been initiated.
Participants note that the reasoning may only be valid for certain types of numbers (e.g., natural numbers) and emphasize the importance of continuity in the context of derivatives. There is also mention of homework guidelines that require showing work before receiving help.
Izzhov
[tex]x^2=x+x+ ... +x[/tex] (with x terms). Its derivative is [tex]1+1+ ... +1[/tex] (also x terms). By this logic, [tex]\frac{d}{dx} x^2=x[/tex] But it doesn't. So what's wrong with this picture?
this is a well known homework problem. So, what makes you think it is valid? What makes you think it isn't?
I think it's valid because the derivative of the derivative of the sum of any number of functions equals the sum of the derivatives of the functions, and multiplication is just repeated addition.
I don't think it's valid because when I plug [tex]x^2[/tex] into the formula [tex]\lim_{h\rightarrow 0} \frac{f(x+h)-f(x)}{h}[/tex] it comes out as [tex]2x[/tex].
I think that it isn't valid, because the book said so, and plugging it into the definition of a derivative is more fundamental (and therefore less likely to be inaccurate) than the rule for the derivative of the sum of functions. However, I can't find the flaw in the first reasoning.
You didn't really help much!
You need to think about when you can apply the rule for derivatives of sums.
Does this work for every x? What if x is pi? -1?
In my mind this is homework. People only get homework help if they actually state what they've done in an attempt. Examine the first premise: that x^2 is x added up x times. That is clearly nonsense.
What you just stated works only for natural values of x. The derivative requires a function that is continuous, not discrete over integers.
You didn't think much. Matt Grime's purpose was to give you something to think about- that's always a great help.
You might also think about how x+ x+ x (exactly 3 times) is different from (x+ x+ ...+ x) (x times). Each is a function of x in what way?
Listen: I have thought about it, contrary to what people may think! If x is [tex]\pi[/tex], for example, you just add [tex]\pi[/tex] three times and then add [tex](\pi - 3) \ast \pi[/tex] and you get [tex]\pi^2[/tex]. I don't see the problem with applying this method to any real number.
That is not the calculation you used before: you said "x2= (x+ x+ ...+ x) (x times)". That is not the same as saying "add [itex]\pi[/itex] to itself 3 times, then add [tex](\pi - 3) \ast \pi[/tex]." That was d_leet's point. Why do you mean by "[itex]\pi[/itex] added to itself [itex]\pi[/itex] times"?
My point was not so much that you can't say that "x2= (x+ x+ ...+ x) (x times)" but rather that the derivative of that is not "(1+ 1+ ...+ 1) (x times)". That "(x times)" is another function of x and you haven't "differentiated" that.
I think the problem itself lies in that there are x terms. I myself find it quite ambiguous but I'm going with it . I'll try and explain:
Since there are f(x) 'x' terms where f(x) is a function of x. In that we would have to differentiate f(x)*x using product rule which would result: xf'(x)+f(x).
Thus we cannot directly apply derivatives of sums because the number of such sums is in turn a function of x.
(Well, now! I don't understand that myself!:-p )
Since there aare f(x) 'x' terms where f(x) is a function of x. In that we would have to differentiate f(x)*x using fromduct rule which would result: xf'(x)+f(x).
that kind of vaguely defined
Actually pretty well stated.
LOL, I like to make up stories!
That makes sense. Thanks a lot. :smile:
You gave no indication of that. We aren't psychics
The 'method' you just used, and the method you gave in the first post are completely different.
I've already figured out the answer to the question (see my last post), and I don't want to get into any arguments with anyone, so I think this thread should be locked before a fight breaks out or something.
What fight? If you read the homework FAQ you will see that homework help is not given unless you show what you've done. That is the primary requirement here for you to get help. So don't complain when you don't get help if you've not done so.
Lol Everyone chillax. If you think this is getting heated, just make a new account Izzhov :p CHill, this is math, not girls :)
It seems you are getting hung up by using the power rule to define the derivative. Power rule is just a short cut for the difference quotient
lim as h-> 0 [f(x+h)-f(x)]/h.
  • · Replies 105 ·
13K
