Positive integral implies bounded below?
The discussion revolves around a problem in real analysis concerning the properties of integrable functions. Specifically, it examines the implications of a positive integral of a function over a closed interval [a, b] and whether this guarantees the existence of a subinterval where the function is bounded below by a positive constant.
  • Participants explore the hint regarding the lower integral and its implications, with some expressing confusion about its relevance to bounding the function. Others suggest considering alternative approaches, such as proof by contradiction or examining specific functions like the Dirac delta distribution and the characteristic function of irrationals.
The discussion is active, with various interpretations being explored. Some participants question the assumptions about the positivity of the function, while others provide counterexamples to challenge the original proposition. There is a recognition that additional constraints may be necessary for the proposition to hold true.
There is a noted ambiguity regarding the positivity of the function, with some participants asserting that the problem implies positivity, while others argue that this cannot be assumed without further conditions. The mention of different types of integrals (Riemann vs. Lebesgue) adds complexity to the discussion.
kirstin.17
The integral of f on [a,b] exists and is positive.
Prove there is a subinterval J of [a,b] and a constant c such that f(x) >= c > 0 for all x in J.
Hint: Consider the lower integral of f on [a,b]
I don't see how the hint helps. Obviously both the upper and lower integrals are greater than 0. I tried considering refinement partitions of J extending to [a,b] but that doesn't get me back to getting the actual function bounded.
Since the lower integral is greater than 0, the lower sum for any partition is greater than 0 as well... I just don't see how this is helping and how to go from the sum/integral back to the original function. Is there a different approach that could be taken? Any help? Thx :)
What about the Dirac delta distribution?
If f is indeed a function, then what can you say about the integral if no such subinterval J, positive constant c exists?
Have no idea what Dirac Delta Distribution is... haven't learned that.
Try proof by contradiction (Lower integral converges to THE integral as norm of partition goes to zero)
Consider the characeristic function of the irrationals in [a,b] (f(x) = 1 if x is an irrational number in [a,b], and f(x) = 0 if x is a rational number in [a,b]). The (Lebesgue) integral of f on [a,b] exists and is b-a which is positive, but it takes on the value 0 infinitely many times in any subinterval J.
That was just for your information. You're probably dealing with the Riemann integral. Suppose there is no subinterval with that property. Then on every subinterval [c,d] for a < c < d < b, what's the minimum value f takes on? What is the lower Riemann sum for that partition? Then what is the lower integral, i.e. the supremum of these lower sums? This should contradict the sentence: "The integral of f on [a,b] exists and is positive."
Well, the function is supposed to be positive, so the characteristic function in AKG's response does not really apply (ya it can be modified). I hope my response was plain enough and will get you started.
gammamcc
Nowhere does it say that the function has to be positive.
gammamcc said:
Well, the function is supposed to be positive ...
You can't assume that. (1) The intent of the problem is to prove that the function must be positive over some subinterval. (2) It isn't true. All you know is that the [itex]\int_a^b f(x)dx > 0[/itex]. For example, [itex]\int_{-\pi}^{\pi/2}\cos x dx[/itex] is positive (1) but the integrand is negative on [itex][-\pi,0)[/itex].
Note that the proposition is false as both AKG and I have given counterexamples. Some other constraints (e.g., continuity) must apply to make to proposition true.
OK. It's just that one is supposed to conclude it's positive ..on an interval. OK? So your are over analyzing it as you throw Lebesgue theory at someone you know is asking a classical analysis question.
  • · Replies 26 ·
