Thread Closed
110V relay help
Share Thread Thread Tools
Feb6-07, 09:11 AM   #1
110V relay help
I am trying to control a 110V fan with a low voltage thermostat. I am pretty new to electrical theory... I would like a basic description of what I need and how to properly wire it. Thanks!
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
>> Researchers use light projector and single-pixel detectors to create 3-D images
Feb6-07, 09:48 AM   #2
You need an Opto-Isolating Triac, this will safely isolate the low voltage side form the high voltage side.
Do an internet search for opto-isolating triacs, get the data sheet on a suitable one and there may be circuits in the application notes.
Make sure you get your work checked by somebody who knows what they are doing before you build it and definately before you plug it in.
Feb6-07, 04:01 PM   #3
For someone who seems new to electricity as does the OP I would recommend starting with the low-tech approach of a plain old relay. I haven't looked for a while, but I suspect Radio Shack has exactly the device you need.
Feb6-07, 04:27 PM   #4
Mentor
110V relay help
What about a line voltage thermostat?
Feb6-07, 06:35 PM   #5
An lm35 temp sensor hooked up to a comparator to trigger a relay is probably the way I would go. You can hook a pot up to the comparator to adjust the reference voltage and act like a thermostat. The last time I used an LM35, I believe it sourced 1mA/degree Celcius.
Feb6-07, 06:46 PM   #6
Recognitions:
Gold Membership Gold Member
Quote by russ_watters View Post
I don't think you want to put line voltage on your temp. control wires. As Averagesupernova says; use a "plain old relay" ...that can be mounted on the fan with the other power devices.
Feb6-07, 07:08 PM   #7
Recognitions:
Homework Helper Homework Help
Quote by dlgoff View Post
When you wire a line votage thermostat, you wire it as in place of a wall switch.
If the fan has a wall switch in a sutible location, you can just substitute.
Feb7-07, 06:28 PM   #8
Recognitions:
"When you wire a line votage thermostat, you wire it as in place of a wall switch."
Okay then.
I wanted to make sure that the OP didn't try to wire line voltage to his existing thermostat.
Feb8-07, 07:14 AM   #9
Recognitions:
Okay then.
Good point.
It's also not trivial to design a safe low voltage controller.
Proper enclosure and isolation layouts are not something to attempt without expert knowledge.
Better off purchasing a suitable UL approved controller.
Thread Closed
Thread Tools
Similar Threads for: 110V relay help
Thread Forum Replies
Converting 110v AC to 12v DC Electrical Engineering 7
What do I need to run 200 LEDs on 110V Electrical Engineering 46
Do transformers (110V-220V) drain much power? Electrical Engineering 2
need to convert 110v to 220v from 110 v inverter Electrical Engineering 1
Help Needed Wiring a Low-Volt switch for 110v circuit... Electrical Engineering 28
