Thread Closed
Variable resistance
Share Thread Thread Tools
Feb7-07, 09:25 PM   #1
Question
Variable resistance
"A circuit has a variable resistance (total 100 ohms) across which is a voltage drop of 12 V supplied by a battery. What must be its resistance if the voltage is to be A) 12V and B) 6.2V?"
2. Relevant equations
V=IR
3. The attempt at a solution
We haven't learned anything besides Ohm's Law for these equations, so I tried plugging in different values to try and dial in the answers, but it didn't work. Is there something I'm missing or am I being asked to solve for two unknowns? Hints appreciated.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb7-07, 10:35 PM   #2
Is that all you have? Diagram? Im assuming total resistance is 100 ohms so for 12 v you have 8.5 amps. Then for 12V, you need a resistance of 12/8.5 but I dont trust this answer. If its a serial pair of resistors where Rx and Ry are 100 ohms and you are being asked the voltage drop across Rx, i think the above is good.
Feb7-07, 10:38 PM   #3
Diagram
Feb7-07, 10:43 PM   #4
Variable resistance
drawing a blank on the diagram, literally
Thread Closed
Thread Tools
Similar Threads for: Variable resistance
Thread Forum Replies
PSPICE help - X variable Electrical Engineering 2
AC Source/ Variable Resistance Introductory Physics Homework 8
Resistance as a Random Variable? Set Theory, Logic, Probability, Statistics 0
Rocket with Variable Mass and Air Resistance. Introductory Physics Homework 2
Automatic variable resistance Electrical Engineering 3
