Resistance of parallel resistors
The discussion revolves around calculating the equivalent resistance of multiple resistors connected in parallel, specifically resistors with values of 5 ohms, 20 ohms, 40 ohms, and 50 ohms.
  • Exploratory, Mathematical reasoning
  • Participants explore the concept of equivalent resistance in parallel circuits and question whether an expression for calculating this resistance is known. Some express curiosity about the nature of the problem, suggesting it may be part of a multiple choice question.
There is an ongoing exploration of the problem with participants sharing different perspectives on how to approach the calculation. Some guidance has been offered regarding the formula for calculating equivalent resistance in parallel, but no consensus has been reached on the final answer.
Participants are discussing the problem without explicit options provided, leading to questions about the nature of the inquiry and the expected format of the answer.
athenaroa
If resistors of 5 ohm, 20 ohm, 40 ohm, and 50 ohms are parallel with each other, the equivalent resistance would most nearly be how many ohms?
Have you no expression for the resistance of parallel resistors?
Well, do you have options? Sounds like a multiple choice question. Nearly how many ohms?
try 1/Rx = 1/R1 + 1/R2 + 1/R3 +1/Retc... !
1/((1/5)+(1/20)+(1/40)+(1/50))
  • · Replies 42 ·
