Register to reply
Satellite orbits and energy
by brunie
Tags: energy, orbits, satellite
Share this thread:
brunie
#1
Feb11-07, 12:27 PM
P: 62
Can't really figure out where to start. Any help would be appreciated.
A 575 kg satellite is in a circular orbit at an altitude of 550 km above the Earth's surface. Because of air friction, the satellite eventually falls to the Earth's surface, where it hits the ground with a speed of 2.10 km/s. How much energy was transformed to internal energy by means of friction?
2. Relevant equations
E = -1/2 G Ms Me / r
v = 2 pi r / T
E = - G Me Ms / Re + d
M = mass
R = radius
3. The attempt at a solution
ok so 575kg, 550000 m above earths surface, falls at 2100 m/s
5.97 x 10^24 kg is earths mass (Me)
6378100 for earth radius (Re)
Ms is mass of satelite
G is constant
so for Ek = 1/2mv^2
= 0.5*575*2100^2
= 1267875 kJ
= (6.67 x 10^-11)(5.97 x 10^24)(575) / (6378100 + 550000)
= -3.305 x 10^10
so do I substract E in orbit by Ek at crash (E - Ek)??
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
denverdoc
#2
Feb11-07, 01:45 PM
P: 1,350
Well we know energy in these situations is conserved, except that lost to drag and heating of the satellite.
So the initial energy in orbit equals the final energy at impact plus that lost due to drag. So see if you can set up some equations for the situation based on that. Since it was in orbit, there may be way to simplify the kinetic energy of the satellite.
brunie
#3
Feb11-07, 02:44 PM
P: 62
ok, yeah i agree, but im not sure if im using the right equations
denverdoc
#4
Feb11-07, 03:10 PM
P: 1,350
well at least take a stab, post what is the total energy in orbit, then what you compute for the potential energy plus kinetic at impact. From there we can help.
brunie
#5
Feb11-07, 03:12 PM
P: 62
Quote Quote by denverdoc View Post
i did take a stab and i did calculate it
Janus
#6
Feb11-07, 03:19 PM
Emeritus
Sci Advisor
PF Gold
Janus's Avatar
P: 2,361
All right let's see if some pointers help
Quote Quote by brunie View Post
This will give you the total energy of the satellite in orbit as measured with respect to the center of the Earth. (providing that r is measured from the center of the Earth.)
v = 2 pi r / T
This will give you the orbital velocity of the satellite. (not really needed to solve the problem)
This give you the potential energy of the Satellite while in orbit as measured with respect to the center of the Eartrh
M = mass
R = radius
G is constant
so for Ek = 1/2mv^2
= 0.5*575*2100^2
= 1267875 kJ
okay for the kinetic energy when the Satellite strikes the Earth
= -3.305 x 10^10
Again, this is just the Potential energy part of the total energy of the satellite in orbit.
What you want to do is find the difference between the Total energy of the Satellite in orbit (the combination of both its kinetic and potential energies), and its total energy when it strikes the Earth (again the combination of both its kinetic and potential energies).
You've got the formula for finding the total energy in orbit and you've found the kinetic energy at impact. You just need to find the potential energy at impact to complete the picture.
brunie
#7
Feb11-07, 03:34 PM
P: 62
wow thank you,
so if im understanding correctly
E = -1/2 G Ms Me / r (total energy in orbit)
Ek = 1/2mv^2 (kinetic on ground)
Ep = mgh (potential on ground)
and therefore E = Ek + Ep + Elost
Elost = - 0.5(6.67x10^-11)(575)(5.97x10^24) / (6378100 + 550000) - 0.5(575)(2100)^2 - (575)(9.8)(6378100)
= -5.37 x 10^10
Im pretty sure thats not right so i probably screwed up sumwhere in my understanding.
Janus
#8
Feb11-07, 04:28 PM
Emeritus
Sci Advisor
PF Gold
Janus's Avatar
P: 2,361
wow thank you,
The problem with this equation, in this situation, is that it assumes that acceleration due to gravity(g) doesn't change with height. This is fine when you are trying to find the potential energy difference between an object sitting on the ground and one 100m above the ground, because g doesn't measurably change btween these two point. This is not the case when it comes to the center of the Earth and its surface.
Instead, go back and look at the equation that gives the potential energy for the Satellite in orbit. Can you see a way of modifying it so that it gives the potential energy at the surface?
Register to reply
Related Discussions
Satellite Orbits Introductory Physics Homework 6
Satellite Orbits... General Physics 4
Satellite orbits Introductory Physics Homework 3
