How can Kirchoff's rules be used to determine current values in a circuit?
  • Thread starter Thread starter Azndude51
    Circuits Rules
The discussion revolves around applying Kirchoff's rules to determine the current values (I1, I2, I3) in a given electrical circuit. The circuit includes various resistances and an emf source, prompting participants to explore the relationships between the currents and resistances.
  • Participants discuss the application of Kirchoff's junction rule and Ohm's law to find current values. There are attempts to calculate total resistance and current using different combinations of equations. Questions arise regarding the correctness of calculated values and the relationships between the currents.
Some participants have confirmed calculations for I1 and are exploring the relationships between I1, I2, and I3. There is acknowledgment of potential errors in submitted answers, and participants are collaboratively checking their reasoning and calculations without reaching a final consensus.
Participants mention discrepancies in submitted answers for I2 and I3, suggesting possible confusion in the values or calculations. The original poster expresses uncertainty about the correctness of their approach, indicating a need for further clarification.
Azndude51
Use Kirchoff's rules to determine I1, I2 and I3 for the following circuit: https://chip.physics.purdue.edu/protected/Prelab221img/e4pp2.jpg
E1 = emf = 9 V
r = internal resistance = 1.5 ohms
R1 = 5 ohms
R2 = 15 ohms
R3 = 22.75 ohms
Find I1, I2, I3
V=IR
I(R1+R2) = V and Req = R1 + R2+ ... for resistors in series
I = emf/R1 + emf/R2 + ... and 1/Req = 1/R1 + 1/R2 + ... for resistors in parallel
Krichoff's junction rule Iin-Iout = 0
I found I1 to be .741 A by using I=V/R with R being the calculated total resistance: (1.5 + 1/(1/22.75+ 1/20) = 12.14
Now I've been using various combinations of the equations above to get the other two I's but I can't seem to get a correct answer, can someone point me in the right direction?
Thanks in advance
Correct
What exactly were you doing?
Note that I1 = I2 + I3
So if I1 = I2 + I3, shouldn't I2 = I1 - I3 = .741 - 9/22.75 = .345?
Yup, that's correct.
DARN IT, I got .345 for I2 when I first tried the problem, but when I submitted it (online) it was wrong, so I posted here. But when I submit it for I3, it is correct (and .396 is correct when I submit that for I2). I think they must've gotten switched. Thanks for the help though, ranger.
:smile: I see what you mean. When I double checked them with the current divider rule, I noticed the same thing. Its just a small mix up, that's all.
  • · Replies 18 ·
  • · Replies 20 ·
