Resonant frequency calculation for lengths of thick wall steel pipe
The discussion revolves around calculating the resonant frequencies of a thick-walled steel pipe, particularly focusing on its behavior in air. The original poster seeks to understand the relevant equations and factors influencing these frequencies, considering the dimensions of the pipe.
  • Participants explore the dependency of resonant frequencies on the pipe's restraint conditions and various modes of vibration. The original poster clarifies their interest in the longitudinal pressure wave resonance and the predominant radial frequencies. There are discussions about the assumptions regarding the coupling of air and pipe resonances and the complexity of finding formulas for thick-walled pipes.
The conversation has evolved with participants providing insights into the complexities of the problem, including the distinction between the resonances of the pipe and the air inside it. Some guidance has been offered regarding the use of Bessel functions for radial frequencies, and references to external resources have been shared to aid understanding.
There is a noted interest in ensuring that the radial frequencies align harmonically with the longitudinal resonance to achieve a pleasant tone, akin to the sound of wind chimes. The original poster expresses a desire for an algorithmic approach to this arrangement.
john.riley2
resonant freq. in air for arbitrary length steel pipe with radius in the 3-8 cm range and wall thickness in the o.5 to 1 cm range
unable to find a relevant equation
You won't be able to find a single relevant equation, for two reasons:
1 The frequencies depend on how the pipe is restrained. That is the probably single most important thing which determines the frequences.
2 There are many different modes of vibration of the pipe, each with its own (infinite) set of vibration frequencies and each governed by different equations. For example if the pipe was not restrained at all, it could vibrate by bending (like a beam), axially (changing length), torsionally, and radially (not just panting in and out, but also the cross section changing from a circle to an ellipse, or a "wavy" shape with any number of waves round the pipe).
resonant frequencies of thick-walled steel pipe
I should further qualify this. Pipe would be unrestrained, and length would hopefully be large compared to diameter and wall thickness. I would be primarily interested in the longitudinal pressure wave resonance, but it would be nice to calculate the predominant radial frequencies for the two strongest modes. Thanks
John
Ah... I thought you were talking about resonances of the pipe, not the air inside it.
If you assume the air and pipe resonances are not coupled (that's a very reasonable assumption for a "stiff" thick walled pipe) the longtitudinal resonances are just the standard "open and closed organ pipe" formulas, and are independent of the diameter of the pipe.
Re the radial frequencies, the solutions to the wave equation are Bessel functions. If the wavenumber k = omega/c and the radius is r, the lowest frequencies are when kr = 3.832, 7.015, 10.174, ... See http://www.du.edu/~jcalvert/math/cylcoord.htm
Sorry...I'm finding that I am ot communicating clearly at all. I am interested in the resonance of the pipe itself, and possibly an algorithm by which I could arrange the radial frequencies to be an harmonic of the longitudinal reaonance so that the tone would not be unpleasant. Think of giant wind chimes! many thanks!
John
OK, now I understand the question.
Finding any formulas for thick shells will be hard. This might give you some leads for thin shells (usually defined as radius/thickness > 10, so your largest radius and smallest thickness are in that range).
"... this thesis presents exact solutions for vibration of closed and open cylindrical shells..." http://library.uws.edu.au/adt-NUWS/public/adt-NUWS20061016.103821/index.html
I haven't read all of it (!) - and apologies if it tells you a lot more about the subject than you really want to know.
  • · Replies 33 ·
