Voltage in a 2 battery series circuit
The discussion revolves around a circuit problem involving two batteries in series and the calculation of current using Kirchhoff's rules. Participants are exploring the relationships between voltage, current, and resistance in the context of series circuits.
  • Participants discuss the addition and subtraction of voltages in the context of opposing battery effects. Questions arise regarding the application of Kirchhoff's rules and the interpretation of voltage rises and drops.
Some participants have offered insights into the reasoning behind voltage calculations, while others express confusion about the application of Kirchhoff's rules. There is an ongoing exploration of different interpretations and approaches to the problem.
One participant notes the urgency of understanding the problem due to an upcoming exam, indicating a time constraint that may affect the depth of discussion. There are also references to specific resistor values and configurations that may influence the calculations.
Dart82
What is the magnitude and direction of the current in the following circuit?
[URL=http://imageshack.us][PLAIN]http://img234.imageshack.us/img234/7587/circuituk2.gif[/URL][/PLAIN]
resistance for series: Req=R1+R2+R3+R4...etc
Kirchhoff's rules --> Loop Rule: sum of potential drops must equal sum of potential rises
V=IR
1st added all the voltage drops: I(5+27+12+8) = I52
2nd added all the Voltage rises: 30 + 10 = 40V
3rd solved for V when V=IR
40 volts/52 ohms= I
*since resistors are in series they experience the same current right?
my answer .77 Amps clockwise [which is wrong] the right answer is .38 Amps clockwise
My question is this: Why am i not supposed to add the voltages (30+10) together when solving this problem?? If i solve for this problem in the following way, 30V-10V = I(52ohms) then i get .38 Amps clockwise (which is right) but i don't understand why i have to subtract the voltages!:confused:
Mark the poisitive side of the cells in your image.
Does that give you a clue?
Yes. It seems the only logical explanation i can think of is that when 2 batteries "oppose" each others flow; then one battery will reduce the voltage of the other.
Yes, the equivalent voltage will either be a sum or (in this case) difference of the 2 voltages. Going in a clockwise loop from A, a particle will go from low potential to high potential (+30V) and then go from high potential to low potential (-10V). If the batteries were arranged + to - in series, you could add the voltages because there would be a rise followed by another rise
i see; i mistakenly counted the 2nd battery as a rise instead of a drop. Thanks again!
i'm staring at the same problem and yet don't get how to solve it ? can anyone offer me any help?! I might have this problem on my final exam this coming monday may 10th , 2010. help please
Which part do you find confusing?
the kirchhoffs rule as a whole. I tried solving this problem in the following way :
R= 1/32 + 1/20 = 0.083 ohms
I= V/R = 30/0.083= 360 amps
which I know is wrong so what can I do, I spent the last hour watching a professor from MIt working a similar problem yet he did not show it with numbers or real answers.
Resistance in series adds like this:
R1=32
R2=20
Rsum=32+20
