Finding a Program to Calculate Slope with Y-Intercept of 0 and Uncertainty
The discussion revolves around finding software tools to calculate the slope of a linear fit line with a y-intercept of 0, while also accounting for uncertainties in both x and y variables. Participants explore various programs and methods for achieving this, including Excel and Graphical Analysis, and seek recommendations for better alternatives.
  • Frímann seeks a program that can calculate the slope of a linear fit line with a y-intercept of 0 and uncertainties on the slope, mentioning difficulties with Excel and Graphical Analysis.
  • Frímann later discovers that in Graphical Analysis, using the "General Equation" Y = AN allows for a fit through the origin.
  • One participant suggests using Gnuplot as a potential solution, providing detailed instructions on how to use it for plotting data and fitting functions.
  • Another participant recommends Grace as a program with a graphical interface for similar tasks.
Participants express interest in various software options, and while some solutions are proposed, there is no consensus on a single best program. The discussion remains open to further suggestions and experiences.
Participants mention specific limitations with the programs they have tried, such as the inability to calculate uncertainties in Excel and the challenges of forcing a y-intercept of 0 in Graphical Analysis. These limitations highlight the need for clearer methods or alternative software.
Students and researchers in physics, engineering, or any field requiring data analysis and linear regression with specific constraints on fit parameters.
dreamspy
Hi
I have some data which concists of some points (x,y) and I'm looking for a program that can calculate for me the slope of the linear fit line (trendline) including uncertanity on the slope. Also the y-interception has to bo at 0.
My data set includes incertanities on both x and y variables.
I have tried this in excel. I can get the slope for the line that has y-intercept = 0, and I can add in the graph my uncertanities, but I can't find out how to calculate the uncertanity of the slope.
I tried another program called graphical analysis. That program can easily give me the slope and the uncertanity of the slope. But I can't seem to find out how to force y-intercept to 0 (force the line through the point (0,0) )
So my questions in general are:
Is there another program that is better suited for this?
How can I calculate uncertanity for the trendline in Excel?
How can I force the trendline (linear fit line) to go through the point (0,0) in Graphical Analysis.
An answer to just one of these questions would be sufficent :)
best regards
frímann kjerúlf
student of University of Iceland
Computer science news on Phys.org
Just seconds after I sent this post I figured out how to do this in Graphical Analysis :) Just use the "General Equation" Y = AN (not Y = AN + b) .
Although I am still interestd in knowing if there are some better programs for making charts, and calculating uncertanities? F.x. calculating uncertanities of a multivariable function, it can get quite cumbersome using paper and pencil.
regards
Frímann
Try gnuplot:
http://www.gnuplot.info/
For the Windows version download the file from
http://gnuplot.sourceforge.net/development/binaries/
(The version from 10-Feb-2007)
The Windows version of gnuplot is called wgnuplot.
To start wgnuplot, unzip the downloaded file and go to the folder
gnuplot\bin
There, click on
wgnuplot.exe
First of all the font in the terminal is too small, so change it with a rightclick on the terminal
background and click "Choose Font". Choose the font you like.
Then work through this excellent tutorial:
http://t16web.lanl.gov/Kawano/gnuplot/intro/index-e.html
Other tutorials can be found here:
http://gnuplot.sourceforge.net/help.html
and there are lots more on google
Here's an example on how to plot data and fit a function to it:
Code:
[b]STEP 1:[/b]
Download this file:
[PLAIN]http://t16web.lanl.gov/Kawano/gnuplot/intro/plotexp.dat[/PLAIN] [b]STEP 2:[/b]
Open the plotexp.dat file with a texteditor and replace the data
by the following:
0	0.1
1	1.03
2	2
3	3.03
4	4
5	5.03
6	6
7	7.03
8	8
9	9.03
10	10
Save the plotexp.dat file.
(Note: The first column contains the x-values and the
second one the y-values.)[b]STEP 3:[/b]
Now put the plotexp.dat file into the folder
gnuplot\bin\[b]STEP 4:[/b]
Start wgnuplot and type the following in the wgnuplot terminal:
gnuplot> plot "plotexp.dat"
This creates a plot of the datapoints.
You can label the x- and y-axis and put a title. Type in the terminal:
gnuplot> set xlabel "name of x-axis"
gnuplot> set ylabel "name of y-axis"
gnuplot> set title "this is the title"
(Note: Instead of typing
you can also type
gnuplot> replot)[b]STEP 5:[/b]
Fitting a function to the datapoints:
Suppose you wanted to do a linear fit, then your function is
f(x) = a*x+b
Thus, type in the terminal:
gnuplot> f(x)=a*x+b
To fit this function to the data, type in the terminal:
gnuplot> fit f(x) "plotexp.dat" via a,b Gnuplot determines:
Final set of parameters                         Asymptotic Standard Error
a               = 0.995455                     +/- 0.002571     (0.2583%)
b               = 0.0454545                    +/- 0.01521      (33.47%)
The values for a and b are:
a   = (0.995455  +/- 0.002571)
b   = (0.0454545 +/- 0.01521)
(Note: You can use other functions for f(x), for example
gnuplot > f(x) = a+b*x+c*x**3
The fit-command then becomes:
gnuplot> fit f(x) "plotexp.dat" via a,b,c
Note that x**3 means x^3.)[b]STEP 6:[/b]
To plot the data and display the fitted line together,
gnuplot> plot "plotexp.dat", f(x) [b]STEP 7:[/b]
- You can also save the graphics and create an output as eps or postscript:
EPS (with color):
gnuplot> set term postscript eps enhanced color
gnuplot> set output "color.eps"
gnuplot> replot
(Note: You can also use another name for the output, e.g. type:
gnuplot> set output "myData.eps")
EPS (only mono)
gnuplot> set term postscript eps enhanced monochrome
gnuplot> set output "mono.eps"
gnuplot> replot
POSTSCRIPT:
gnuplot> set output "data.ps"
gnuplot> replot
(To view ps files, you need a program called Ghostview and Ghostscript,
[url]http://www.cs.wisc.edu/~ghost/gsview/index.htm[/url])
You will then find the eps or ps file in the gnuplut\bin folder.
Finished!
NOTE:
- By pressing up and down key (on your keyboard) in the terminal, you can choose former commands you typed
- I had to download the "plotexp.dat" and edit it because
saving the datapoints in a txt file (test.txt) and opening the txt file
with gnuplot didn't work. For some reason only the .dat file is recognized
by wgnuplot.
- Unfortunately I don't know how to create a jpeg file with wgnuplot.
GnuPlot is a good choice, but if you are looking for a program with graphical interface try http://plasma-gate.weizmann.ac.il/Grace/" .
