Y's Work on a Test Charge: Calculating Work Done in an Electric Field
The discussion focuses on calculating the work done on a positive test charge in an electric field, specifically using the equation W = PE2 - PE1 = -qEd. The electric field was determined to be 5.4 x 10^6 N/c, leading to a calculated work of 2.025 J when moving the charge 0.25 m. The negative sign indicates that the work is done against the direction of the electric field, confirming the principles of electric potential energy. The final formula correctly reflects the potential energy difference, affirming the calculations presented.
  • Understanding of electric fields and their calculations
  • Familiarity with the concept of electric potential energy
  • Knowledge of the formula W = -qEd for work done in electric fields
  • Basic algebra for manipulating equations
  • Study the relationship between electric fields and potential energy in more complex scenarios
  • Learn about the implications of negative work in electric fields
  • Explore the concept of electric potential difference and its calculations
  • Investigate the applications of work-energy principles in electric circuits
Students studying electromagnetism, physics educators, and anyone interested in the principles of work and energy in electric fields.
rgo
I am looking at quation 10 but it relates to question 9
http://137.186.166.185:8080/question.gif
In question 9 I calculated the electric field to be 5.4 X10^6 N/c.
I did this by using the equation E = K(Q/r^2)
I would assume that I would use this equation for question 10
therfore
W = -(1.5x10^-6 C)(5.4 x 10^6 N/c)(0.25m)
W= -2.025 J
The sign is negative because the work is in the opposite direction of the electrical field.
This seems to be too simple. Am I missing something?
Thanks for the help
Youre moving a positive test charge from lower potential to higher potential, so the work done on the charge is potential energy at D - potential energy at B. What does that say about the sign?
I think I got it
Thats right, so my final fomula should be:
W = (1.5x10^-6 c)(5.4 X10^6 N/c)(0.25m) - (1.5x10^-6 c)(0)(0.25m)
W = 2.025 J
Thank you for your help
RG
  • · Replies 22 ·
