Calculate Mass of Paradichlorobenzene for .05 Molal Solution
The discussion focuses on calculating the mass of paradichlorobenzene required to create a 0.05 molal solution in 20.00 mL of cyclohexane. The molar mass of paradichlorobenzene is 147.01 g/mol, and the density of cyclohexane is 0.779 g/mL. The calculation performed involves determining the mass of cyclohexane, which is approximately 15.58 g, and using the formula for molality to find that 0.11 g of paradichlorobenzene is needed. The calculation appears to be correct based on the provided values.
  • Understanding of molality and its calculation
  • Familiarity with density and mass-volume relationships
  • Knowledge of molar mass and its application in solution preparation
  • Basic algebra for solving equations
  • Review the concept of molality and its significance in solution chemistry
  • Learn how to calculate mass from volume using density
  • Explore the properties and applications of paradichlorobenzene in laboratory settings
  • Study the implications of solution concentration on chemical reactions
Chemistry students, laboratory technicians, and anyone involved in solution preparation and concentration calculations.
babbagee
Calculate the mass of paradichlorobenzene (M=147.01g/mol) that should be added to 20.00 ml of cyclohexane (d = .779g/ml) to make a .05 molal solution.
I did this problem but i don't know if i did it correctly.
first i found the mass of cyclohexane by using m=dv.
(.05moles solute/kg solvent)(15.58g)(1kg/1000g)(147.01g/mol) = .11g
does this seem correct. I am not sure.
Thanks.
Chemistry news on Phys.org
That's what I got...
9K
  • · Replies 131 ·
11K
