Solving for Time and Velocity in Hot-Air Balloon and Ski Jumping Scenarios
  • Thread starter Thread starter hyen84
    Physics
The discussion revolves around two physics problems involving kinematics: one concerning a hot-air balloon releasing a ballast bag and the other about a ski jumper's trajectory after leaving a ramp. Participants are seeking guidance on the appropriate equations to use for these scenarios.
  • Participants discuss the need for specific equations related to uniformly accelerated motion and question whether all necessary information has been provided for the ski jumper's problem.
Some participants have offered hints regarding the equations that could be applied, while others express a preference for manual calculations over programming solutions. There is a mix of approaches being considered, but no consensus has been reached on the best method to tackle the problems.
There is mention of potential missing information in the ski jumper's scenario, and a participant has indicated a preference for using formulas rather than computational programs, which may influence the direction of the discussion.
hyen84
More Physics Help please...
i need help with this 2 physics question..can someone help me please...thank you very much...which equation should i use...
1. A hot-air balloon is rising straight up with a speed of 5.00 m/s. A ballast bag is released from rest relative to the balloon when it is 2.95 m above the ground. How much time elapses before the ballast bag hits the ground?
2.After leaving the end of a ski ramp, a ski jumper lands downhill at a point that is displaced 66.7 m horizontally from the end of the ramp. His velocity, just before landing, is 18.3 m/s and points in a direction 32.2 degrees below the horizontal. Neglecting air resistance and any lift that he experiences while airborne, find (a) the magnitude and (b) the direction of his initial velocity when he left the end of the ramp.
Why don't you give them a try and show us what you know?
Here's a hint. One equation for uniformly accelerated motion is:
[tex]Y = Y_i + V_{y,i}T + \frac{1}{2}aT^2[/tex]
For the second problem, did you leave any information out?
Help... coming Hopefully
Well We did a lot of calculations like your second problem in my class... So many in fact that I wrote a program that does all the calcualtions and can add stuff like friction... however I seem to have misplaced my caclulator right now. When I find it i will try to remember to come back to help.
Heh, you really don't need to write a program to do this kind of stuff.
I think you should just try to apply the equation Doc Al has kindly posted.
cookiemonster
Program
The program was written by myself for myself... In order to program something you need to know it inside and outside. I know how to do these problems by hand as well cookiemonster.
I'd argue that point. You don't need to know something inside and out in order to convince a calculator to do it for you. You just need a formula.
It's not my contention, though, that you don't know how to solve these kinds of problems. I just don't really understand why one would write a program for a simple problem such as this. A program for Fourier Series or Newton's Approximation Method (I've personally written programs for each of these, and quite a few others) I can understand.
cookiemonster
Please guys don't argue..i don't want it to be b/c of me asking for help that turn into an argument...if the program work for Tom McCurdy, that's great..but i like to do things hand on..so..i'm doing it using formulas... thanks guys for your help...
