What is the formula for the family of quadratic functions passing through (3,0)?
The discussion revolves around finding the family of quadratic functions that pass through the point (3,0). Participants are exploring the implications of this condition within the context of quadratic equations.
  • Participants discuss substituting the point into the quadratic equation and express confusion about the meaning of a "family" of functions. There are attempts to express parameters in terms of one another and to understand how to derive a general form from the given condition.
The discussion includes various interpretations of how to express the family of quadratic functions. Some participants suggest different methods for eliminating parameters, while others seek clarification on the process. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants are working under the constraint of the quadratic equation format and the specific point through which the functions must pass. The discussion reflects uncertainty about how many parameters can be eliminated based on the given condition.
wellY--3
A family of quadratic functions passes through the points (3,0). Find the family of quadratic functions
err i have no idea hwo to do it except substituting those values in ... 0=9a+3b+c
what does it meant the family of quadratic functions?
And then find a in terms of b and c
b in terms of a and c
c in terms of a and b
then put them back into the original quadratic.
From two equations, in general, you at most can eliminate only one of the unknowns. So from the original y=ax^2 +bx +c, you can remove only one of a or b or c.
Write, a in terms of b and c (or, b in terms of a and c; or, c in terms of a and b) and put in the original... that is your family of equations for any choice of the existing two parameters.
what??
and put in the original what
so c =-12x
is that right?
No, c = -(9a + 3b).
So the family is,
[tex]y(x) = a x^2 + b x -(9a + 3b)[/tex]The one given condition only let's you eliminate one unknown parameter. So you end up with a quadratic function that still has two free parameters, that's why it's referred to as a "family", there's lot of 'em. Get it?
The point is that any "quadratic function" can be written in the form
y= f(x)= ax2+ bx+ c. You want to write a formula that describes the "family" (i.e. set) of all those that pass through (3,0)- that is, all those for which y= 0 when x= 3. Putting y= 0 and x= 3 into that original formula,
0= 9a+ 3b+ c so c= -(9a+3b). The answer to the question is that the family of all quadratic functions that pass through (3, 0) are those of the form f(x)= ax2+ bx- (9a+ 3b).
(That's one way to write the answer: we could also, of course, have solved 9a+ 3b+ c= 0 for a, in terms of b and c, or for b, in terms of a and c, and replaced that parameter instead of c.)
  • · Replies 30 ·
9K
  • · Replies 46 ·
16K
