How to Solve a Challenging Physics Problem with Proportional Acceleration?
  • Thread starter Thread starter SheldonG
The discussion focuses on solving a physics problem involving proportional acceleration, where the acceleration of a body is proportional to the distance traveled. The user, Sheldon, attempts to derive the distance traveled as a function of time using the equation \( a = ky \) and integrating to find \( v^2 = ky^2 + v_0^2 \). Despite initial errors in integration, Sheldon ultimately recognizes the correct solution is \( y = \frac{v_0}{2\sqrt{k}}(e^{\sqrt{k}t} - e^{-\sqrt{k}t}) \). The conversation highlights the importance of careful integration techniques in deriving solutions to complex physics problems.
  • Understanding of differential equations, specifically the relationship between acceleration, velocity, and distance.
  • Familiarity with integration techniques, particularly in the context of physics problems.
  • Knowledge of exponential functions and their properties, especially in relation to motion equations.
  • Basic grasp of kinematics and the principles of proportional acceleration.
  • Study the derivation of motion equations under constant acceleration.
  • Learn advanced integration techniques applicable to physics problems.
  • Explore the application of exponential functions in solving differential equations.
  • Review examples of proportional acceleration scenarios in classical mechanics.
Students of physics, educators teaching kinematics, and anyone interested in mastering the application of differential equations in motion analysis.
SheldonG
A body has acquired a downward velocity [itex]v_0[/itex] and thereafter the acceleration is proportional to the distance traveled. Measure time and distance from the instant and place where the object has acquired the velocity [itex]v_0[/itex] and find the formula or the distance traveled as a function of time.
Suggestion in text to use
[tex]\frac{dv}{dt} = v\, \frac{dv}{dy}[/tex]
I have found this problem very challenging. I'd appreciate any suggestions. I know it's long and complicated, and I am asking a lot, but if any of you have time, it really would be appreciated.
Using the suggestion in the text, I started with [itex]a = ky[/itex] which means [itex]\frac{dv}{dt} = ky[/itex] or
[tex]v\frac{dv}{dy} = ky[/tex]
My idea here was to get an expression for v, and then integrate that (as dy/dt) to get y in terms of t. But I have never really seen something like this before in the text. So perhaps I took a wrong turn here. What I tried to do was this: [tex]v\, dv = ky\, dy[/tex] and integrate this to get [tex]v^2/2 = ky^2/2 + C[/tex].
I know the book says you aren't supposed to view dv/dy (or any derivative) as a fraction, but I couldn't think of anything else to do.
On the off chance this was ok. I found [itex]C = v_0^2/2[/itex] and so end up with [itex]v^2 = ky^2 + v_0^2[/itex].
So (assuming this is right), I have [tex]\frac{dy}{dt} = \sqrt{ky^2 + v_0^2}[/tex] I use the theorem on reciprocals to write it as [tex]\frac{dt}{dy} = \frac{1}{\sqrt{ky^2 + v_0^2}}[/tex]
To integrate this, I set [itex]y = v_0\tan\theta/\sqrt{k}[/itex] and so [itex]dy/d\theta = v_o\sec^2\theta/\sqrt{k}[/itex] and I end up with the integral
[tex]t = \frac{1}{\sqrt{k}}\int \frac{1}{\cos\theta}\, d\theta = \frac{\log(\cos\theta)}{\sqrt{k}} = \frac{1}{\sqrt{k}}\log\left(\frac{v_0}{\sqrt{v_0^2 + y^2k}}\right) + C[/tex]
So
[tex]De^{\sqrt{k}t} = \frac{v_0}{\sqrt{v_0^2+y^2k}}[/tex]
and
[itex]D = 1/v_0[/itex].
Here is where I stopped, since it is obvious that this is not going to lead to the correct answer as given in the book, which is
[tex]y = \frac{v_0}{2\sqrt{k}}(e^{\sqrt{k}t} - e^{-\sqrt{k}t})[/tex]
Thanks again, if anyone has the fortitude to slog through all this.
Sheldon
Now I see a mistake in my integration of 1/cos. Let me think on this some more, and I will post again. Sorry to bother everyone.
Sheldon
Yes, that was the problem. Well, I managed on my own for once. Sorry to bother anyone who read this.
Thanks
Sheldon
  • · Replies 105 ·
13K
  • · Replies 22 ·
