Bathroom scale on one of the Earth's poles
  • Thread starter Thread starter psruler
    Poles Scale
When standing on a bathroom scale at one of the Earth's poles, the scale reads 700.0 N due to the gravitational force acting on the individual. At the equator, the scale reading will be slightly less than 700.0 N because of the centrifugal force resulting from the Earth's rotation, which acts against gravity. This centrifugal force is strongest at the equator and decreases towards the poles. Although the difference in scale readings is minimal and often unnoticeable on standard bathroom scales, it is a direct result of both the centrifugal force and the slight variation in gravitational pull between the equator and the poles.
  • Understanding of gravitational force and normal force
  • Basic knowledge of centripetal force and centrifugal force
  • Familiarity with Earth's rotation and its effects
  • Concept of net force in physics
  • Calculate the centripetal force required for an object at the equator using the formula F = mv²/r
  • Explore the differences in gravitational acceleration at different latitudes
  • Investigate the effects of Earth's rotation on various physical phenomena
  • Learn about the principles of force measurement using scales
Physics students, educators, and anyone interested in understanding the effects of Earth's rotation on weight measurements and gravitational forces.
psruler
I need help on this problem:
Suppose you stand on a bathroom scale on one of the Earth's poles, and it reads 700.0 N. If you stand on the same scale on the Earth's equator, and your mass is unchanged, what will be the scale reading on the equator? (Remember that the scale tells you the normal force of the ground on you.) Assume the Earth is a perfect sphere of constant radius.
The point of this problem is that the scale reads the "net" force on you: the force of gravity minus the "centrifugal force" due to rotation.
(I just know I'm going to get into trouble for saying that! People are going to complain that "centrifugal force" is a fictitious force. Yes, that's why I put it in quotes! It would be more correct to say that part of the gravitational force goes to keep you rotating with the Earth and the rest to pressing you against your scale.)
At the pole you are not "rotating" (you are kind of slowly pivoting in place). The scale reads the gravitational force.
At the equator you are rotating. You are going in a circle equal to the circumference of the Earth every 24 hours. Calculate the (centripetal) force necessary to do that and subtract from your weight at the pole.
The scale reading on the equator will be slightly less than 700.0 N due to the centrifugal force caused by the Earth's rotation. This force is strongest at the equator and decreases towards the poles. Therefore, the normal force of the ground on you will be slightly less on the equator compared to the poles. However, the difference in scale readings will be very small and likely not noticeable on a regular bathroom scale. Additionally, the scale reading may also be affected by the slight difference in gravitational pull at the equator compared to the poles, but again, this difference would be very small. Overall, the scale reading on the equator would be very close to 700.0 N, but slightly less due to the effects of the Earth's rotation.
12K
  • · Replies 23 ·
15K
