Confusing wording? Energy conservation part two
The problem involves a two-stage rocket with a mass of 900 kg traveling at a high speed when an explosion separates it into two equal mass sections. The question focuses on determining the speed and direction of each segment post-explosion and calculating the energy supplied by the explosion, with a specific emphasis on the relative speed of the segments.
  • Participants express confusion regarding the wording of the problem, particularly the concept of relative speed and its implications for the motion of the rocket segments. There is discussion about whether one segment must be moving faster and the other slower after the explosion, and how direction factors into their motion.
Participants are actively engaging with the problem, questioning the assumptions made in the wording and exploring the implications of relative speed. Some guidance has been offered regarding the conservation of momentum and the need to clarify the direction of motion, but no consensus has been reached on the interpretation of the problem.
There is a noted lack of visual aids, such as diagrams, which some participants feel would help in understanding the problem better. The discussion also highlights the distinction between relative speed and speed with respect to the ground, which is a source of confusion.
Shazbot
A 900-kg two-stage rocket is traveling at a speed of 6.50 x 10^3 m/s away from Earth when a predesigned explosion separates the rocket into two sections of equal mass that then move with a relative speed (relative to each other) of 2.80 x 10^3 m/s along the original line of motion. a) What is the speed and direction of each segment after the explosion? b) How much energy was supplied by the explosion? [Hint: What is the change in kinetic energy as a result of the explosion?]
E = K + U = (.5)mv^2 + mgy
This doesn't look like too difficult a problem, but I'm confused by the wording that the text here uses. Specifically, the part where it says that their speed in relation to each other is 2.80 x 10^3 m/s which is slower than they were both moving a moment ago. If an explosion has separated the rocket into two pieces, wouldn't one be moving more quickly and the other be moving more slowly? Is it trying to say that one piece is now moving 1.40 x 10^3 m/s faster and the other is moving 1.40 x 10^3 m/s slower (this is all I could come up with)? :confused: Similarly, if they're both moving at that speed along the original line of motion, why does it ask for the direction of their motion as well? I don't see any indication in the problem that either piece has changed course... I'm sure it can't be too difficult a problem, but I really wish there had been some kind of accompanying diagram. If anyone could help by writing this out in a way I could understand it (or drawing it if it'd be easier) I'd be a happy camper.
They are talking about relative speed, not speed with respect to the ground. For example, if one is moving at 100 m/s up and the other at 101 m/s up, then their relative speed is 1 m/s.
Yes.
The wording makes it sound as if they are both now moving at 2.80 x 10^3 m/s :confused: Similarly, if they're both moving at that speed along the original line of motion, why does it ask for the direction of their motion as well?
Direction can be up or down. I suggest you call up positive and down negative.
Hint: This in not an energy conservation problem. Mechanical energy is not conserved in an explosion. But something else is conserved. What? :wink:
Conservation of momentum, of course. I swear that's that I meant to say :-p
Wait, so then it's saying that one piece gets blown higher up and the other piece gets blown down (in relation to the original trajectory)? Wouldn't they then not be traveling "2.80 x 10^3 m/s along the original line of motion"? Is it something else? I'm having trouble visualizing what's happening here...
I guess my question could be written a bit more simply as: by "two sections of equal mass that then move with a relative speed (relative to each other) of 2.80 x 10^3 m/s along the original line of motion" does it mean that piece 1 is traveling at 2.80 x 10^3 m/s in relation to piece 2 (which would be traveling at 0 m/s in relation to piece 1)?
or
does it mean that both pieces are traveling at 2.80 x 10^3 m/s and, if so, how is this possible considering one has to be slowed down and the other sped up by the force of the explosion?
and
how does direction factor into all of this?
Good answer. :wink:
Originally, the two rocket pieces are traveling at the same speed: 6.50 x 10^3 m/s upwards. After the explosion, the top piece is traveling at speed Vt and the bottom piece is traveling at speed Vb. Their relative speed is 2.80 x 10^3 m/s. It's up to you, using conservation of momentum and the given data, to find the actual final speeds with respect to the ground.
Almost. The top piece is traveling at a relative speed of +2.80 x 10^3 m/s (up) with respect to the bottom piece and, conversely, the bottom piece is traveling at a relative speed of -2.80 x 10^3 m/s (down) with respect to the top piece. Note that I use + to mean "up" and - to mean "down".
It doesn't mean that.
By direction they mean sign. Is it going up or down? You know the top piece must be going up, since it picked up speed with the explosion. But the bottom piece may just slow down (and thus keep going up) or perhaps is now going in the opposite direction--down. That's part of what you need to figure out.
To solve this:
(1) Calling the final speeds Vt & Vb, write an equation for conservation of momentum.
(2) Write another equation for their relative velocity.
  • · Replies 20 ·
  • · Replies 18 ·
