Divide a Number by 0: Is it +infinite or -infinite?
  • Context: High School
  • Thread starter Thread starter JPC
The discussion centers around the concept of dividing a number by zero, exploring whether such an operation results in positive infinity, negative infinity, or remains undefined. Participants engage in theoretical reasoning, mathematical definitions, and implications of division by zero across various contexts.
  • Some participants assert that division by zero is undefined, emphasizing that no real number can satisfy the equation resulting from such a division.
  • Others propose that dividing a positive number by a value approaching zero from the positive side leads to positive infinity, while approaching from the negative side leads to negative infinity.
  • A participant questions the nature of zero, asking whether it is positive, negative, or undefined.
  • Some argue that the definition of division by zero as undefined is a human construct, suggesting that mathematics is a man-made system that dictates its own rules.
  • Several participants provide logical reasoning to support the claim that infinity is not a number, thus making division by zero undefined.
  • There is a discussion about limits, with some participants attempting to relate division by zero to limit processes, questioning if similar rules apply to limits as to ordinary equations.
  • One participant expresses confusion about the relationship between integration and division by zero, indicating a lack of clarity on the topic.
Participants generally agree that division by zero is undefined, but there are competing views regarding the implications of approaching zero from either side and the nature of infinity. The discussion remains unresolved with multiple perspectives presented.
Some arguments rely on specific definitions of mathematical operations, while others challenge the foundational assumptions of arithmetic. The discussion includes unresolved mathematical steps and varying interpretations of limits and infinity.
JPC
Hey just wondering
if u divide any real number by 0 is it + infinite or - infinite
is it : +infinite when the number if positive, and -infinite when the number is negative ?
Mathematics news on Phys.org
Technically, division by zero is undefined; but, essentially yes, with a few modifications: dividing a positive real number by a number which approaches zero through positive values approaches [tex]+\infty[/tex]. Consider the graph of [tex]y=\frac{3}{x}[/tex] below:
note that the function value (or y value) approaches [tex]+\infty[/tex] as x approaches zero through positive values (from the right side of zero); but the function value (or y value) approaches [tex]-\infty[/tex] as x approaches zero through negative values (from the left side of zero).
yeah but i mean , is 0 positive or negative ?
or is it just undefined as u said ?
0 is neither positive, nor negative and division by 0 in arithmetics over reals is undefined.
Dividing by zero does not result in infinity, it results in undefined. Here's why:
The division operation, by definition, is the inverse of multiplication. 6/3 is equal to 2 because 2*3=6.
But if we try that with zero, we start with 0*x=6. This equation has no solution at all - there is no value of x (including infinity) that can make that equation true.
Since the multiplicative has no solution, the inverse has no solution (not even infinity).
Dividing by zero is undefined. In fact when someone says a number A (positive) divided by zero, he means it is divided by an epsilon and then find the lim of the result when epsilon approaches to zero. So depending the sign of epsilon, the result can be + infinitive or - infinitive. I mean epsilon can approache zero origine either from the left or from the right then we have -0 or +0.
Does he mean that? I don't think so..
SHOULD he mean that? He certainly should not.
I don't understand why some people are obstinate about undefined operations. Mathematics is not nature made, it's man made, and man dictates its functioning. How we define our numbers and their arithmetic makes the expression x / 0 irrelevant. It does not mean anything.
INFINITY IS NOT A NUMBER! Thus we cannot define dividion with zero. To prove that infinity is not a number
let suppose
inf = 1/0;
then 0* inf = 1,
but 0 = 1 * 0 = 0 * (0 * inf ) = (0 * 0 ) * inf = inf * 0 = 1
Contradiction.
Thus division with zero is still remain undefined.
dextercioby: 0 is neither positive, nor negative and division by 0 in arithmetics over reals is undefined.
The standard proceedure with historians is to go from 1BC to 1AD, thus 1000AD is 999 years after 1 BC. If you consider BC to be negative and AD to be positive, well then, as you see here, there is no such thing as year 0, so it can not be positive or negative in this system.
What does that have to do with anything? :confused:
Hurkyl: What does that have to do with anything?
i am sorry if this is troublesome, i thought it was a joke. I could have added, it does illustrate the fact that 0 was not accepted by early historians, and so the tradition just continued. It is the reason why we are now in the 21st Century, but in the year 2007.
Yes- it does not mean anything because it is not defined to be anything- it is undefined. When you refer to people being "obstinate" about undefined operations, exactly what do you mean?
But simply declaring that "it is undefined because we say so" is not a satisfactory answer.
There IS a good, logical reason why it is undefined, and it can be shown, as posts 5 and 9.
There are two separate issues here.
"It is (un)defined because we say so" is essentially the only correct answer to the question "Is it defined?" There is no higher reason for it -- either an expression syntactically satisfies the requirements of a definition, or it does not.
1/0 is undefined (for real division) precisely because this expression fails to satisfy the requirement that the dividend is a real number and the divisor is a nonzero real number. Similarly, if x is a variable denoting a real number, then x/x is undefined. (y/y would be defined if y is a variable denoting a nonzero real number, though)
You are talking about the reason why we would ever have chosen to define division this way. There is a good reason for that. (I think "practical" is more accurate than "logical", though) But the reasons for choosing the definition are entirely irrelevant to the question of what is or is not defined.
Why would you insist that we defined it a certain way before there was a reason to need it to be that way? Isn't that putting the cart before the horse? Or a fabulously lucky premonition?
Surely, the historical order of occurrence is:
1] We "invent" division (as the inverse of multiplcation)
2] We realize that dividing by zero is problematic
3] We put in place a rule so as not to cause problems
I'm not. There is a difference between the question
"Why is 1/0 undefined?"
and the question
"Why did we define division so that 1/0 is undefined?"
If we say y(a number) divided by x as x approched infity equals 0. Can we say 0 times x as x approches infity equals Y.
Does division by 0 is undefined for only real numbers or all complex numbers.
minase said:
y divided by x as x approched infity equals 0
This doesn't make sense. I will assume you meant to say:
"The limit of y divided by x, as x approaches infinity, equals 0"
or equivalently
"y divided by x approaches 0 as x approaches infinity"
Similarly, I will assume you meant to say
"The limit of 0 times x, as x approaches infinity, equals y"
or equivalently
"0 times x approaches y as x approaches infinity"
The second statement does not follow (directly or indirectly) from the first. The second statement is true iff y = 0.
Can you use the same rule for limits as an ordinary equation y/x=0, 0*x=Y.
"If we say y(a number) divided by x as x approched infity equals 0. Can we say 0 times x as x approches infity equals Y."
"limit of y/x, as x goes to infinity, y fixed, equals 0" is only true if y is not 0.
No, we cannot say "0*x, as x approaches infinity equals y". 0*x for any real x is 0 so the limit is 0.
When we did integration isn't it the same thing what we were doing when adding up all the rectangles. The sum of all the rectangles as dx approches 0. Sorry i am a bit confused. Math is not my strongest subject.
No, it's not at all the same thing.
ZioX said:
Don't you guys know? 1/0 = infinity and 0^0=0/0 = golden ratio. How poetic!
http://www.bbc.co.uk/berkshire/content/articles/2006/12/06/divide_zero_feature.shtml
I shed a tear for those kiddies learning such trash.
No, we don't know that because it isn't true. "infinity" is not a number so 1/0= infinity is non-sense. The golden ratio is a number but neither 00 nor 0/0 is so that last statement is false.
Are you referring to us kiddies having to read your trash?
(I just went and looked at the website- Ah, you were being sarcastic! Sorry about that.)
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 73 ·
