Angular Momentum Homework: Calculating <Lz> & ΔLz
The discussion revolves around calculating the expectation values of angular momentum components, specifically and ΔLz, for a superposition of spherical harmonic functions in the context of quantum mechanics. The original poster references a textbook for guidance on these calculations.
  • The original poster attempts to calculate and ΔLz using formulas from their textbook but questions their results after receiving feedback on their assignment. They inquire about the difference between and as defined in their context.
  • Another participant provides an alternative calculation for and suggests a different value for ΔLz, prompting further inquiry into the methods used.
  • There is a discussion about the validity of applying textbook formulas to a linear combination of spherical harmonics, with some participants suggesting that this may not be appropriate.
The discussion is ongoing, with participants exploring different interpretations of the calculations and questioning the application of established formulas. Some guidance has been offered regarding the nature of the state being analyzed, but no consensus has been reached on the correct approach or results.
Participants are navigating potential misunderstandings regarding the application of formulas to a superposition of states, and there is an acknowledgment of the complexity introduced by this linear combination. The original poster expresses uncertainty about how to proceed with their calculations.
stunner5000pt
For the spherical solution of the Schrödinger equation in spherical coordinates given the superposition of spherical harmonic functions
[tex]\frac{1}{\sqrt{14}} (Y_{1,-1}+ 2Y_{1,0}+3Y_{1,1})[/tex]
calculate [itex]<\hat{L_{z}}>[/itex] and [itex]\Delta L_{z}[/itex]2. The attempt at a solution
now from my textbook (brehm and mullin)
[tex]<\hat{L_{z}}> = \hbar m_{l}[/tex]
[tex]<\hat{L_{z}}> = \frac{\hbar}{14} (-1 + 4(0) +9(1)) = \frac{8}{14} \hbar = \frac{4}{7} \hbar[/tex]
while [tex]<L_{z}^2> = (\hbar m_{l})^2[/tex]
this implies that the uncertainty in the Z component of the angular momentum [itex]\Delta L_{z} =0[/itex]
but i was marked wrong in my assignment for this...
am i missing something
is there a difference between [itex]<\hat{L_{z}}>[/itex] and [itex]<L_{z}> [/tex]?<br /> <br /> thanks in advance for any input[/itex]
<L_z^2>=(+1+0+9)/14=5/7.
Thus, you should get Delta L_z=3/7.
[itex] <br /> <br /> How did you get that<br /> <br /> [tex]\langle L_{z}^2\rangle = (\hbar m_{l})^2[/tex] ?[/itex]
my textbook says so...also
[tex]<L_{z}^2>=\int \Psi^{*}_{nlm}\left(\frac{\hbar}{i}\frac{\partial}{\partial\phi}\right)\left(\frac{\hbar}{i}\frac{\partial}{\partial\phi}\right)\Psi_{nlm} d\tau = (\hbar m)^2[/tex]
Yes, but in your case the state is no longer [itex]\langle r, \theta, \varphi|n, l, m \rangle[/itex] , but a linear combination of spherical harmonics. So blindly using a fomula in the book is a wrong decision...
... I am not sure how to proceed then...
do i 'prove' it?
thanks for the help so far...
but could you look at this thread of mine... its in more of ugent need ...
https://www.physicsforums.com/showthread.php?t=157392
  • · Replies 21 ·
  • · Replies 0 ·
