Question about fourier transform
The discussion revolves around the Fourier transform of a specific function, x(t) = exp(-t/a) * sin(a*t), where a and b are constants. Participants also inquire about the Fourier transform of a function that follows a normal distribution.
  • Participants question the convergence of the Fourier transform for the given function and discuss the conditions under which x(t) is defined. There is also a mention of using MATLAB for numerical calculations and a request for an analytical expression for the Fourier transform.
The discussion includes attempts to clarify the definition and properties of the Fourier transform, with some participants suggesting starting from the definition itself. Questions about the setup and assumptions of the function are being explored, but no consensus has been reached on the analytical approach.
There are constraints regarding the definition of x(t) for t < 0 and t >= 0, which are under discussion. Additionally, the participants are navigating the implications of using numerical methods versus seeking an analytical solution.
fanxilong
hi every one!
i want to know the Fourier transform of x(t)
x(t)=exp(-t/a)*sin(a*t), where a ,b is constant
and can it be work out by matlab?
another question is :
how to proof the Fourier transform of x(t) who follows normal distribution n(u, sigm^2 ) is also normal distribution ?
thanks !
Do you have your powers correct in the exponential? x(t) doesn't look like it would have a converging FT. Note, that as t -> -infinity, x(t) is unbounded.
BTW: sin(a*t) can be written in terms of complex exponentials.
BTW: sin(a*t) can be writting in terms of complex exponentials.
yes, you are right , it should be like this:
x(t)=0 for t<0
x(t)=exp(-t/a)*sin(b*t) for t>=0
and then ?
Hi! MATLAB calculates things numerically. If you plug in numbers corresponding values for that function, then I believe the FFT ("fast Fourier transform") algorithm will spit out numbers for the Fourier transform (can't recall if you have to work out the frequencies yourself).
This is NOT what you want though. You want an analytical expression for the Fourier transform of that function, right? So my question is, what is the hang up here? In other words, where are you having a problem. Start with the *definition* of the Fourier transform, and go ahead:
[tex]X(\omega) = \mathcal{F}\{x(t)\} = \int_{-\infty}^{\infty} x(t)e^{-i \omega t}\,dt = \int_{0}^{\infty} (e^{-t/a}\sin(bt))e^{-i \omega t}\,dt[/tex]
I think I got that right, but I'd double check it if I were you.
Again, what is the issue? You know the definition of a Fourier transform, right?
