Can neutrinos pass through each other due to electrostatic repulsion?
  • Context: Graduate
  • Thread starter Thread starter nolanp2
The discussion revolves around the interactions between neutrinos, specifically whether they can pass through each other due to electrostatic repulsion or other principles, and the implications of their behavior at a subatomic level. The scope includes theoretical considerations and conceptual clarifications regarding particle interactions and quantum mechanics.
  • One participant questions if neutrinos could pass through each other, suggesting that if electrostatic repulsion is the only force preventing objects from overlapping, then neutrinos might not be hindered in the same way.
  • Another participant notes that while particles can interact through direct collision, neutrinos have an extremely small cross-section for such interactions.
  • A different viewpoint introduces the Pauli exclusion principle, stating that neutrinos, like electrons, would be repelled from one another if they share the same spin state, preventing them from occupying the same position.
  • One participant raises a question about whether this repulsion implies that a particle is being accelerated without the influence of the four fundamental forces.
  • A later post mentions the concept of an "exchange interaction term" in the Hamiltonian, which relates to the spins of the particles and may influence their interaction potential.
  • Another participant inquires whether this potential could effectively reduce the probability of certain states to zero, but later indicates they have resolved their question without needing further explanation.
Participants express differing views on the nature of neutrino interactions, with some suggesting that electrostatic forces and quantum principles like the Pauli exclusion principle play significant roles, while others focus on the implications of particle collision and interaction probabilities. The discussion remains unresolved with multiple competing perspectives.
There are limitations regarding the assumptions made about the forces acting on neutrinos and the definitions of interaction terms in quantum mechanics, which are not fully explored in the discussion.
nolanp2
if the only force preventing one object from pasing through another is caused by electrostatic repulsion of electrons, does this suggest that a neutrino would pass through another neutrino if they were to be fired at each other? could both particles actually exist at the same coordinates?
Particles on a subatomic scale can interact by direct collision, although for neutrinoes the cross-section is extremely small.
Like electrons, neutrinos are repelled from one another by paulis exclusion principle - meaning that if two particles are in the same spin state they can't be in the same position state causing them to move apart.
but doesn't that mean that the particle is being accelerated even without anyone of the four fundamental forces acting on it?
Someone please answer this guy. This is really interesting.
When we look at systems in detail, there is often an "exchange interaction term" in the Hamiltonian that looks like the dot product of the spins of the two objects. See the Wikipedia article on this topic, for instance.
That term in the Hamiltonian represents a potential, does it not ? It will be zero or some negative value depending on the dot product. It this sufficient to reduce the probability of finding that state to zero ?
Added later : I've sorted this out, no need to explain.
  • · Replies 21 ·
