Calculating Potential Difference in a Parallel-Plate Capacitor
  • Thread starter Thread starter AznBoi
    Capacitor
The problem involves calculating the potential difference in a parallel-plate capacitor with a charged object suspended between the plates. The object has a specified mass and charge, and the setup includes an angle formed by the thread suspending the object.
  • Mixed
  • Participants discuss the relevance of the object's mass in the solution, questioning how it interacts with the electric forces and the tension in the thread. There is exploration of using forces and components to analyze the situation.
Participants are actively engaging with the problem, offering insights into the relationship between the weight of the mass and the electric force. Some guidance has been provided regarding the use of forces in both the x and y directions, although there remains some confusion about the contributions of the electric force.
There is an indication that the original poster is unsure about the accuracy of their calculations and the role of mass in the problem. The discussion reflects a learning process with participants questioning assumptions and clarifying their understanding of the setup.
AznBoi
A small object with a mass of 350mg carries a charge of 30nC and is suspended by a thread between the vertical plates of a parallel-plate capacitor. The plates are separacted by 4 cm. If the thread makes an angle of 15 degrees with the vertical, what is the potential difference between the plates?
First, I drew a diagram. Since the object has a + charge, it would be more closer to the negative plate.
[tex]\Delta V=\frac{U_{E}}{q}[/tex]
[tex]U_{E}=qEd[/tex] , [tex]E=\frac{kq}{r^2}[/tex]
Now that I have all the required info to solve for the electrical potential energy, I solved it and put it into the equation: [tex]\Delta V=\frac{U_{E}}{q}[/tex]
For the electrical potential energy I got: 2.023*10^-4J
For the answer (the potential difference) I got: 6742.5V
Does my method seem correct? This is an even problem so I have no way of checking my answer for accuracy. Thanks in adv. :smile:
Do you use the mass of the object in your solution...:wink:
xD I knew that I left something out.. So does that mean my solution doesn't work? I don't know how to use mass in this equation. Do I have to use forces or something?? F=ma?
Indeed, if the mass is suspended (i.e. stationary) what can you say about the weight of the mass in relation to the force exerted on it by the electric field?
Well you can use the weight to find the y component of tension and then solve for the x component of tension. Then you use F=ma with the electric force exerted opposite of the x component of tension?
So will it be:
[tex]\Sigma F_{x}=0[/tex]
[tex]-T_{x}+F_{e}=0[/tex]
[tex]F_{e}=T_{x}[/tex]
Then you use this equation:
Instead, you solve the electrical potential energy with the electric force?
[tex]U_{E}=F_{e}*d[/tex]
Sounds spot on to me, but don't forget the electric force will also contribute towards the forces in the y direction :approve:
Alrighty, thanks for your help! =] But I don't get how the electric force contributes to the forces in the y direction. Aren't the plates parallel and vertical? So wouldn't the electric force be horizontal, therefore only contribute to the x direction? I 'm probably wrong, but that's how I invision it to be.
Oops, my bad, I misread the question, I though the plates were at an angle :frown: . You're right, and its time for me to take a break...:rolleyes:
  • · Replies 18 ·
