Rockets burning in terms of momentum conservation
The discussion revolves around analyzing the physics of rockets, specifically focusing on momentum conservation and the implications of fuel consumption on acceleration during launch. Participants are exploring the mathematical relationships and principles involved in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants are attempting to derive the acceleration of a rocket by considering the conservation of momentum and the changing mass due to fuel consumption. There are discussions about using calculus and differentiating to understand thrust and momentum changes. Questions are raised about the definitions and roles of variables such as R, Vex, and the mass of the rocket.
The discussion is ongoing, with participants providing hints and guidance on how to approach the problem. Some are clarifying concepts and encouraging the original poster to articulate their understanding and the specific question they are trying to answer. There is a mix of interpretations and suggestions being explored.
Participants are navigating the complexities of variable mass systems in rocket physics, with some noting the importance of distinguishing between different types of momentum and the implications of constant versus variable fuel consumption rates. There is an emphasis on ensuring clarity in the definitions used throughout the discussion.
lebbo
Can some one help me with this question please. don't really understand
mathematically analyse, using diagrams, rockets burning in terms of momentum conservation and the rate of fuel consumption R and derive the acceleration for a rocket during its launch stage.
Well, what do you know about the topic? What equations do you know? Show your work, and people will help you; however, we will not simply do your homework for you!
lemme give u a tip...you need to remember that the mass is not constant and that the fuel used is continuously reducing the mass of the body...try to a get a start, use calculus and post how far you get...
Be careful when you're looking for an explanation -- many high school/introductory undergraduate textbooks derive the rocket expressions with scalars, although they use vector tactics along the way. As I recall, Serway was one of the few that had a decent, correct explanation.
Also, the Internet is your friend. We're not going to just tell you how to do the problem, but nothing's stopping you from hunting down explanations online. That way, you'll learn by working through the derivations on your own.
sry about that
we know that rockets momentum final= R
then the F= R/t
were R is the rate of fuel consumption and F is the total thrust
am i gettin there ?
Well.. you might want to start by considering that momentum is always conserved.
If we imagine the rocket sitting in outer space it can make the thought process simpler.
If we assume initially the rocket is stationary its initial momentum will be zero, after it starts accelerating the total momentum of the system will still be zero (1st clue).
Secondly... Momentum = Mass * Velocity, however, in this case the mass of the rocket is not constant! Try working out the Thrust via differentiation.
Why do you describe "R" as both the rate of fuel usage and the change of momentum?
ok i think R=M/T
and therefore F=(R)(Vex)
Vex is the velocity when the rocket loses the fuel because it goes faster with less weight
total momentum intial= (M+m)V=0
total momentum final=M(V+v)=0
therefore total momentum: (M+m)V=M(V+v)
m : this is delta m is the fuel (before and after)
but wat do i do with the fuel that is expelled
When you write F=R*Vex, if as you also say R=M/T
This is the thrust. However you then describe Vex as something other than the exhaust velocity (then it is not the thrust). Also, its very unclear what you mean by M and m.
Before you try solving this for the general case in which R might vary take R to be constant. Let's also assume that the exhaust velocity is constant.
I say this because your momentum equations look rather confused and we should sort that out first.
Vex = exhaust vel.
Mf = mass of Fuel.
M = Initial mass of rocket.
V = final mass of rocket
Once the rocket has used all its fuel...
Vex*Mf = (M-Mf)*V
Which is the bog standard cons. of mom. eqn.
If your ok with this then we can set up the "rocket equation".
yea i get wat ur doing
ur sayin momentum before=momentum after
I notice that you still haven't said exactly what the question is. That is important in deciding how to answer it!
  • · Replies 47 ·
  • · Replies 42 ·
  • · Replies 17 ·
  • · Replies 22 ·
